Waste gate
Results 1 to 13 of 13
This is a discussion on Waste gate within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Is there anything I should do to my stock turbo if I'm adding an aftermarket wastegate? And will the aftermarket ...
    Registered User Scottplageman's Avatar
    Jan 2014
    North carolina
    Waste gate
    Is there anything I should do to my stock turbo if I'm adding an aftermarket wastegate? And will the aftermarket wastegate give me more psi out of my stock 2005 wrx turbo.
    The spring pressure of the aftermarket unit may need to be adjusted to work with your ECU parameters, or else you can see poor boost performance (slow response, oscillations, etc).
    Resident Tuner @ WTF Tuning
    Palmyra, NJ
    Grimmspeed makes a block off bracket for it.
    And adding an EWG won't give you more boost per say...you have to tune to increase boost. It will help to regulate correct boost parameters (as long as it's set up and adjusted correctly) from the ECU as EJ says.
    May 2010
    Pittsburgh, PA
    Adding an EWG will not give you any more 'psi' out of the stock turbo, unless incorrectly installed.
    You'll need to get your ECU retuned for it. You'll also need to block off your turbos IWG.
    No offense, but judging off of your post, there is no reason at all your should be putting an EWG on your car. They are expensive, require a retune on your car, will not yield a substantial power gain for the price, and most importantly - can easily and quickly blow your engine if not installed properly.
    2011 STi Build Log
    Jan 2014
    North carolina
    On that note, making the arm shorter by screwing it in, is a bad idea as well?
    Palmyra, NJ
    What are you trying to accomplish here?
    Jan 2014
    North carolina
    I'm broke but want more power
    Palmyra, NJ
    Quote Originally Posted by Scottplageman View Post
    You have to pay to play.
    Only way you can safely add power is to either tune for it ($$$$) and go stage 1ish...or add parts that will increase power (stage 2 or more), and TUNE for those parts ($$$$$$$$$).
    Unless you want to blow up your car, then sounds like you are SOL.
    May 2010
    Pittsburgh, PA
    I'm broke but want more powerTapatalk
    Considering an external wastegate normally runs $500 and up for the wastegate and up-pipe... plus install time... and tuning.... I think you should probably just do some reading. Reading is pretty cheap.
    Even if you were to raise your boost pressure by one means or another (adjusting your wastegate arm length probably would not help much in that department, anyhow), its a pretty awful idea. When you are running more than 14psi of boost, you better be adjusting your timing along with it.
    Bottom line is that if you are broke and want more power, you need to either make more money or learn to like your car as is.
    2011 STi Build Log
    Jan 2014
    North carolina
    I'm new to the turbo game, I've been wanted to get a wrx and I finally did. An now that I have it I'm lost haha I went from an 06 legacy to an 05 wrx
    May 2010
    Pittsburgh, PA
    I'm new to the turbo game, I've been wanted to get a wrx and I finally did. An now that I have it I'm lost haha I went from an 06 legacy to an 05 wrxTapatalk
    As I said - reading is free. I don't mean to come off overly abrasive, but 2.5L engines that put out 300hp aren't toys, despite what most people seem to initially assume. If treated properly, they aren't cheap. If treated improperly, they are unreliable and a small fortune.
    There are some good posts around these forums. Check out some people's signatures for some good ones. Also look around for "Unabomber's Manifesto" over on NASIOC - its not a bad read or reference to get you started.
    2011 STi Build Log
    Jan 2014
    North carolina
    Alright thanks guys, I'm gonna do a load of research before I play around in the engine bay. I'll start with my exterior first haha
            MainFrame's Avatar
    Austin, TX
    An external wastegate will cost you at least $500, plus the cost of the tune.. and just trying to turn up the boost without tuning will blow your engine. New engines aren't exactly cheap.
