Cracked CV boot Repair
Results 1 to 11 of 11
This is a discussion on Cracked CV boot Repair within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my front right CV Boot on my 2004 WRX (111,000ish Miles) is cracked and leaking. It's super expensive to ...
    Registered User Hobbitrabbit's Avatar
    Jan 2014
    Cincinnati
    So my front right CV Boot on my 2004 WRX (111,000ish Miles) is cracked and leaking. It's super expensive to fix, and I don't have a ton of money- do any of you know what it entails and if it's possible for me to do it myself?
    Jan 2014
    Cincinnati
    The repairman said the axle might have to be replaced, but from what I was shown the boot was merely leaking. Unsure what that means.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by Hobbitrabbit View Post
    You sure about that? My dealer replaced one with all OEM parts at the last service for less than $300. It's certainly doable yourself, but if you get nervous, it shouldn't be that bad at a dealer either. They're a wear item, so shop's do them all the time.
    2007 Outback 3.0R wagon
    Jan 2014
    Cincinnati
    I was quoted around 300 Dollars. I'm 18, and that's a lot of money for me, haha. I'm not nervous about doing the work myself, if I can, I just don't actually know what would need to be done. I suppose some research is in order haha.
    Did you see the links provided in response to your initial question? Inside there is a specific list of what needs to be done and with what parts and tools.
    True.
    Jan 2014
    Cincinnati
    Ah, I did not. I will look at that.
    Jan 2014
    Cincinnati
    Okay, it's looking like I'm going to have to replace the whole axle. I did find this site MW Enterprises, quality remanufactured Subaru Axles in the links provided on one of the other threads- does anyone know if these are reliable and work well? I'm not inclined to pay 300 Bucks to have it fixed when I can replace it myself for half that or less.
    Registered User boone1186's Avatar
    Dec 2011
    Minnesota
    It's much easier to replace the whole axle, but if you're worried about money just buy a boot kit and only replace the boot. It will set you back maybe $40.
    2010 WRB WRX
    Jan 2014
    Cincinnati
    Yeah, thats probably what I'll end up doing, if its cheaper.
    $80 to do it well; $100 if you need to buy one or the other band tool (you need both styles).
