Boost doesn't go over 5mpa is what boost gauge reads? why?
Results 1 to 11 of 11
This is a discussion on Boost doesn't go over 5mpa is what boost gauge reads? why? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So today I just installed the restrictor pill back onto the car cause previous owner must have removed it. Boost ...
    Registered User Crazygerman's Avatar
    Dec 2013
    Boerne, Tx.
    So today I just installed the restrictor pill back onto the car cause previous owner must have removed it. Boost does not go over .05MPa that is what boost gauge is marking. ??? Any input on this??? Is this normal boost level? 02 impreza wrx .....thanks a bunch!
    Dec 2013
    Boerne, Tx.
    Any advice is well appreciated thank you!
    Crazygerman02WRXWagOn
    Jun 2013
    Danbury, CT
    What are those units again?
    Can't be megaPascals (MPa).
    20 PSI is roughly 140 kPa (kiloPascals).
    Sent from my KFAPWI using Tapatalk HD
    Dec 2013
    Boerne, Tx.
    Yes Sir the factory boost gauge on the steering has....0 to .05 , .1 , .15 going up and down 0 to.-.05, -.01 and it has MPa. I ii
    Dec 2013
    Boerne, Tx.
    I don't know what the MPa stands for.. I was thinking it measurement but I have no clue. And now with the restrictor pill it wont go over the .05 mark?
    Dec 2013
    Boerne, Tx.
    Jul 2012
    Rocky Top
    If it's the factory boost gauge it should read in bars.
    Dec 2013
    Boerne, Tx.
    Yes today at dealership they said it is a factory gauge that came as an option. The pic shows exactly what I have. It only goes up to that positive .05 will not pass it in any gear.???
    Jun 2013
    Danbury, CT
    Quote Originally Posted by Crazygerman View Post
    Ah, that pesky decimal point.
    0.15 MPa is 21.55 PSI. I don't know the spec on an '02, but 7 PSI (less than 0.5 bar) seems low.
    Moderator Donkey's Avatar
    Da boonies,Va
    Where did you put the pill? Should be about .1 Mpa at peak boost​ tapering to around .5 Mpa on a stock vehicle.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2013
    Boerne, Tx.
    Thanks you all for the advice and help!
