2004 WRX Gasoline smell and puddle
Results 1 to 10 of 10
This is a discussion on 2004 WRX Gasoline smell and puddle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm well aware as to why I smell gasoline when my car is idling at cold temps here in PA ...
    Registered User MisterNBG's Avatar
    Jul 2012
    PA, USA
    I'm well aware as to why I smell gasoline when my car is idling at cold temps here in PA during the winter. But well after the engine has been warmed up, I kept smelling gas. So I popped the hood. I saw that right next to my power steering pump, on the engine block, there seemed to be a puddle of gas. It's like near the passenger side intake manifold closest to the front of the car. That's what it seems like to me anyways. Definitely smelled like it to. So do any of you have any experience on this? What it might be and how to fix it? I've read that it might have something to do with my fuel rails? idk... I'm obviously frustrated right now.
    Car has 130k miles on it. Still seems to drive fine. Now I'm just worried of a fire starting in the engine bay while driving.
    If you need any more info, let me know!
    Jul 2012
    PA, USA
    Bump
    Feb 2010
    I did a quick search online and found this "It's leaking from the two fuel lines on the right bank under the intake and manifold. If you start your car and get a flashlight, shine it just above the radiator hose connection, under the intake, you will see the two rubber lines connecting to the metal fuel rail fittings. When the car is cold, the lines contract, harden and leak under pressure. Once the car heats up the rubber expands and stops the leak. The fitting on the lines is weak and was a terrible design flaw by Subaru. The rubber has a high failure rate due to its proximity to intense engine heat over time. Remove the intake, replace the hose clamps and hoses if needed and your problem will stop."
    I would check with the dealer to see if there is any recalls, this was a well known problem with 02/03 wrx's yours might fall into the 03 category since its a 2.0 liter engine.
    Also here is a video http://youtu.be/UhCAyOsfPQM
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    Jul 2012
    PA, USA
    Quote Originally Posted by paulsav View Post
    Also here is a video Subaru 2004 WRX STi raw fuel smell fix. - YouTube
    Thanks, yeah I've read all this before posting, I was just curious if anyone had personal experience with this issue. I know that doing the job myself will be a major PITA and a garage will charge around $350 after it's all done. I'm currently in contact with SOA trying to see if I could get a "Good will" repair. I'll keep you all updated!
    Feb 2010
    Quote Originally Posted by MisterNBG View Post
    Good luck Dude!! hopefully they will take care of the repair, since its not users fault and its a manufactures defect, fuel should not leak from the fuel lines.
    Jul 2012
    PA, USA
    Okay so after emailing SOA my troubles, asking about good will repairs and complaining ( a little) here was what they replied with.
    "Dear Nik,
    Thank you for contacting Subaru of America, Inc.
    We appreciate you taking the time to share this situation with us. I am glad that you emailed us because we did not have your name on file as the current owner of this vehicle. I've updated our records so you will now be included in all of the various owner mailings. While I was making this update, I noticed that your vehicle has an open recall. It's involving the Front Lower Control Arm. Please contact your local Subaru dealer to schedule an appointment for this service.
    At that time, you may want to see if they can evaluate your vehicle's fuel smell concern. I would be happy to review their findings so please feel free to let me know when your appointment is set.
    Sincerely,
    Kelly Shinault
    Subaru of America, Inc. "
    Feb 2010
    "Dear Nik,
    Sincerely,
    Kelly Shinault
    Thats a good start! Time to go to the Subaru dealership and see what they say. If they refuse, press on them saying that its a liability because your car can catch on fire and its dangerous to drive it they should take care of it.
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    for the control arm they test it and grease it up or something.
    I had my 02 fixed with the fuel smell TSB. I took it up there and talked to them. They'll want to verify it themselves. Mine didn't do it if i was good and warmed up. It was warmed up from driving up there, they wanted me to leave it overnight.
    If they hassle you too much, tell them it smells of fuel every morning you drive and its below whatever temp you start smelling fuel at.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
    Jan 2016
    The fuel hoses constrict in cold weather causing leak. I had exact same issue... Fuel was spilling out of mine onto manifold causing engine to heavily smoke! Found out Subaru recalled the 2002 & 2003 models with this problem, but not my 2004 ! They sell a replacement kit for this (part# 10130AA000) but the top half on the engine has to come off in order to repair. It's a big job! Called Subaru of America recall dept but was told it's not a manufacturing flaw if it hasn't happened until now. THE CAR HASN'T BEEN IN COLD WEATHER UNTIL I RECENTLY BOUGHT IT! It blows my mind that they're not doing anything about all of these cars with the same problem! If we ban together we might be able to get it recalled. Even if you have already repaired the problem, you can get reimbursed.
    Here is the link for the US Dept of Transportation for reporting vehicle safety issues like this.
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    They have the power to force a manufacturer to do a recall and repair our cars for free.
