Engine/boost sputter when accelerating hard
Results 1 to 15 of 23
This is a discussion on Engine/boost sputter when accelerating hard within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello all, I am having the following issues : When accelerating in gears 3-5, the engine seems to sputter, as ...
    Jan 2014
    Canada
    Hello all,
    When accelerating in gears 3-5, the engine seems to sputter, as well, I can see the boost levels dipping while this is happening. My friend who was driving behind me said that he seen it backfire. The whole car jerks, sometimes really noticeable, other times its very subtle.
    This is a new car to me, it is a 2002 WRX with 266000 kms. Previous owner did timing belt at 180000kms as well as a pro-tune, and complete turbo-back exhaust.
    I have not done any testing as I do not have any equipment for it at the moment. I will check for CEL's when I can.
    Also, another problem I have, is the car's ABS was turned off, the previous owner bought it that way and has no idea how it was turned off.
    If anyone can give me any insight, that will be fantastic.
    PS. I have been looking around for the issues on the forums, but no issues like mine?
    Jan 2012
    Philly Area
    Do you know what tuner they used?
    - Will
    Jan 2014
    Canada
    No idea. I was told they went to a professional tuner.
    Jan 2014
    Canada
    Bump
    Jan 2014
    Canada
    It seems to happen when I have over 10psi boost. Could it be a turbo issue?
    Jan 2014
    East Coast
    Remove and resecure all your IC pipes with new clamps and check them for cracks. You will need to remove them from the car to perform this properly. It sounds like you have a loose connection or a possible crack in one of your hoses which is opening when you hit a certain boost level. This will cause the exact symptoms you are seeing. Also, inspect your spark plugs and as others said, address the tune if none of the above work (white plugs = lean, brown or darker = rich).
    Good luck!
    Chris
    '14 WRX Crystal Black/SPT CBE/Tuned by Torqued Performance
    Jan 2014
    Canada
    You mean spark plugs, right chris410?
    Jan 2014
    East Coast
    Quote Originally Posted by omfg5041 View Post
    Correct, I added a little more detail about the spark plugs. He will be able to get a better idea on how his car is running by reading them. If they look as though the car is running lean, I would highly suggest having it tuned ASAP.
    However, from the description, the IC pipe inpsection is a good starting point. Hopefully, it is an easy fix.
    Chris
    Jan 2014
    Canada
    Would it be worth upgrading the Intercooler if it is the piping that is broken? or just upgrade the hoses?
    Palmyra, NJ
    Check to see if the fuse for the ABS was pulled.
    Jan 2014
    East Coast
    That would be up to you, just replacing the hoses (if they need to be replaced) would be enough.
    Chris
    Palmyra, NJ
    Replacing the intercooler would be pointless if you don't have any other mods, or plan on getting tuned for it anyway.
    Jul 2012
    Rocky Top
    How hard are we talking? Real hard...or just mehh hard. Like how hard? Really really hard?
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    Have you cleaned your MAF? Probably not the problem, but it wouldn't hurt. I like to start with easy fixes first.
    Jan 2014
    Canada
    wreckingball man, do you mean the sputtering jerking?
    Miggs, no I have not. I will be doing a big maintenance/repair job on it on monday, so I will try that then.
    I cannot wait to rip apart my entire rear end to replace the gas tank, brake lines, and replace my front axel... woohoo...
