Engine/boost sputter when accelerating hard - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Engine/boost sputter when accelerating hard within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey all, I found broken intercooler, that appears to have resolved most of the issue. Just driving about an hour ...
    Jan 2014
    Canada
    Hey all, I found broken intercooler, that appears to have resolved most of the issue. Just driving about an hour later and now it's a different problem...
    Please help this is heart breaking.
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Well that sounds like a pulley is going bad. You need to try to pinpoint EXACTLY where the squeaking is coming from then we can go from there. Could be the AC compressor pulley, that is where I search around first. Sometimes these squeaking problems can be fixed with a little bit of WD-40. But if you do decided to try the WD-40 try your best to be careful to not get it on the belt or the part of the pulley that the belt makes a connection on.
    EDIT: fixing this annoying squeak will help you to hear and focus on other noises that you are concerned about.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Jan 2014
    Canada
    Here are more videos
  6. #19
    Jan 2014
    Canada
    And another. It revs, but wont drive right at all
  7. #20
    Jan 2014
    Canada
    Now it won't start. Turns over but not starting. It huffs and puffs, and nothing. Before this happened, i was giving it gas, then it slowed down, have it more gas until it was full throttle and it was barely revving 2250 rpm. Any help would be greatly appreciated.
  8. #21
    Jan 2014
    Canada
    bump
  9. #22
    Jan 2014
    Canada
    heres a new video New video - YouTube
  10. #23
    Jan 2014
    East Coast
    I had a feeling it was an IC connection causing your issue, I had that issue a few times on my Supra. Ok, so now that you have it fixed check over all connections, it is possible you loosened something else. If they all check out, look over your MAF and make sure it is pointing in the correct direction and that the connector is on tight. I would also pull the negative battery terminal and press your brake lights a few times to make sure you have no residual power. Reconnect and try starting the car again.
    I would inspect your plugs as well, it's possible that you fouled them out. Dark = rich while ligth color indicates lean. If they are "medium brown" color they are most likely OK. Of course, if you have not replaced them in a while, it would not hurt to do so. Again, the first place I would start is by making sure your IC connections are all secure, I've accidentally left gaps after replacing a connection and caused the issue to become far worse. It happens!!!
    Chris
    '14 WRX Crystal Black/SPT CBE/Tuned by Torqued Performance
