Changed spark plugs, now engine rattle at end of throttle cycle - 2005 WRX
Results 1 to 8 of 8
This is a discussion on Changed spark plugs, now engine rattle at end of throttle cycle - 2005 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I changed my spark plugs yesterday with NGK Iridiums and also installed a new fuel filter. Put everything back together, ...
    Jun 2011
    I changed my spark plugs yesterday with NGK Iridiums and also installed a new fuel filter. Put everything back together, ran fine, but now I'm getting a rattle at the end of a throttle cycle. If I rev up to anything over about 1500 rpm, as the throttle drops back down, there is a rattle from the passenger side, sounds like it might be coming from the head or something. Could I have overtightened the plugs or something?
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Did you gap your plugs ????
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Did you move anything else and have something like a heat shield rattle? Since it happens as you get off the gas it's probably something like that...
    Jun 2011
    Quote Originally Posted by cogito View Post
    I didn't manually gap them as they come at the correct gap (so they say anyway) .030"
    Jun 2011
    Quote Originally Posted by Ingo View Post
    On that side, I only removed the air intake box. I wondered the same thing since there's no rattle when applying throttle, only as it winds down.
    Feb 2011
    Washington
    Quote Originally Posted by thornhill View Post
    you should always check the gap on new spark plugs.
    Did you figure out where the noise was coming from?
    Dec 2013
    Grand Rapids, Michigan, United States
    Make sure you got them tight enough too. If they aren't, they could be leaking
    Jul 2013
    Southern NH
    Also check your coil packs. Had an issue on deceleration with a coil pack. Hopefully you already have it solved ????
