wiper problems - 2010 wrx
Results 1 to 5 of 5
This is a discussion on wiper problems - 2010 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My drivers side wiper is moving slower than my passenger side on my 2010 wrx sedan. This happened after a ...
    May 2012
    My drivers side wiper is moving slower than my passenger side on my 2010 wrx sedan. This happened after a bad ice storm and I worry i damaged the motor after trying to use the winshield wipers. They still work but because the passenger side moves faster than the driver, the driver side does not go through full rotation as it get blocked by the passenger wiper. When I try to rotate the driver side wiper by hand with the wipers off it moves freely, whereas the passenger side does not. Should I replace the whole assembly or is it a matter of torquing the right part on the driver side? Any help would be really appreciated.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    My guess would be that the mounting of the arm is effed. You may be able to get away with just tightening it up. Under the cap where the arm mounts there is a nut, tighten that up.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    In my experience if you lose the motor both wipers would be affected. So ^
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Palmyra, NJ
    Sounds like the connecting point might be worn or loose, so it would be freely spinning inside the wiper itself. New or replacement wiper arm would probably be needed.
    Registered User PBallen's Avatar
    Jul 2011
    New Hampshire
    +1 to these guys above. I had this just the other day.
    Pop off the plastic piece which is on the pivot point of the arm. Loosen the nut, and take the arm right off. You'll see the splined section of the arm to be striped. Talked with a Subie mechanic, he said they design these to break rather than the motor. Part is $50.
    All I did was take a little rubber washer, force it over the spline, and tighten her back on. Has worked for a week so far - no problems.
