Idle and fan behavior
Results 1 to 7 of 7
This is a discussion on Idle and fan behavior within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey again, recently bought an 04' WRX and I noticed a couple of things that I find odd (compared to ...
    Registered User Crazyced's Avatar
    Dec 2013
    Ottawa
    Arrow Idle and fan behavior
    Hey again, recently bought an 04' WRX and I noticed a couple of things that I find odd (compared to other cars).
    -Warm idle sits right at 500rpm (is it too low? It sounds a little sluggish).
    -Idle will raise a bit just before the fans kick in.
    -Fans kick in about every 15 seconds, only for about 1 to 2 seconds (very short burst).
    Anything out of the ordinary?
    2004 Subaru Impreza WRX
    2004 Dodge Neon SRT-4
    Your tach cannot measure 500 RPM. The first graduated line is higher.
    Fan errors should generate a CEL. Is there a CEL?
    Is the defroster on?
    - Al Stewart
    Palmyra, NJ
    Any mods on the car?
    Any kind of cooling problems that you've noticed?
  5. #4
    Dec 2013
    Ottawa
    Ah fair enough, I guess it's at 750. No CEL (no code either) but I would have to check the defroster.
    Speaking of which, I have noticed that my fan position knob will not go to the very end clockwise (which would be the defrost). I checked and it effectively goes from defrost/foot to defrost only but the knob itself won't go all the way.
    Known mods are K&N filter, axle back exhaust and springs. An alarm system was installed along with ricer LEDs for the footwells. A DVD along with amp and subs used to be in the car but it was brought back to stock before the sale.
    I don't think I have any cooling issues. It was low on coolant at first but I topped it off and it seems stable now (even with spirited driving). I am not discarding the possibility of bubbles in the system though.
    I will do some more testing, making sure the fans are not on defrost and come back to you.
  6. #5
    Palmyra, NJ
    Yeah burp the system to be safe.
    Possible the thermostat could be going?
  7. #6
    Quote Originally Posted by Crazyced View Post
    The knob on mine hesitates but does eventually go. Not without convincing though. Unrelated to your question though since the previous setting, with the footwell/defrost combo, would also use the defroster -- and so would also engage the A/C, which is what I was getting at.
    I don't see a direct connection (yet?) to the issue.
    Please do so. Also consider looking at the engine (safely!) when it's running to see if you can figure out what else happens when the fans engage. I'm betting the A/C is kicking in.
    I'd expect a less rhythmic, and more pronounced effect though. Maybe? I have some doubts.
    - Al Stewart
  8. #7
    Dec 2013
    Ottawa
    Turns out being the defroster.
    Thanks everyone.
    I have read however that the grounding mod helps smooth out the idle. I'm tempted to give it a try.
