Well i cant figure it out letssee if you can
Results 1 to 12 of 12
This is a discussion on Well i cant figure it out letssee if you can within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my turbo used to hold psi just fine on my 03 wrx ( has up n down pipes n ...
    Aug 2011
    So my turbo used to hold psi just fine on my 03 wrx ( has up n down pipes n tbe intake bcs and stage two tune) now when i hit boost it pegs the stock gauge at about 14 psi then its likemy turbo just shuts off till its around 9 psi then spools back up to 14 and continues to do that the whole time i have it floored. Ive steamed my engine to try and fine a vacume leak and tryed differnt tunes. Anyone have any ideas on what it is or howtofix it? i counted it in third gear it jumps back n forth like that 9 times before redline.
    WannaBeExpert
    Sep 2013
    Montrose, CA
    let me give this a shot! this symptom is the ECU and the waste gate solenoid doing its job, have you check if your restrictor pill is where it should be? that is not partially clogged? the only way you can find vacuum leaks is only when you are on boost, so get a mighty vac and do a vacuum test with 20 psi into the system... hope this helps or at least is a starting point on troubleshooting....
    cheers
    Aug 2011
    ok
    Quote Originally Posted by blusuby View Post
    cheers
    Ok I'll do that at my shop today as for the restrictor pill where would that be located and anything special I should use to clean it? Or just use our parts cleaner bin?
    WannaBeExpert
    Jul 2012
    Rocky Top
    The pill is located between the nipple on the turbo cold side and the tee in the line.
    Technical Articles
    Also, for testing the system for leaks you do not have to go to 20psi and there are some hoses you need to unplug and cap. I believe Perrin has a write up on this and if it's the one I'm thinking of, it's the most detailed and deliberate write up I've read anywhere.
    Registered User subypete's Avatar
    Jan 2008
    Forsyth, IL
    Quote Originally Posted by WannaBeExpert View Post
    WannaBeExpert
    You say you have a BCS? Is it a 3-port BCS? If so, you won't have a restrictor pill. Also, when you say steamed I am assuming you mean smoked. Steam condenses to water... you obviously don't want that in your intake.
    You need to find a way to take some data logs and post them here so that people have a better idea of whats going on. Do you have an AccessPort or a Tactrix cable? If you can, log the following:
    A/F Correction #1(%)
    A/F Learning #1(%)
    A/F Sensor #1(AFR)
    Engine Load (g/rev)
    Engine Speed
    Feedback Knock Correction
    Fine Learning Knock Correction
    IAM
    Ignition Total Timing
    Injector Duty Cycle
    Intake Air Temperature
    Manifold Absolute Pressure (PSI)
    Manifold Relative Pressure(corrected)(PSI)
    Mass Airflow (g/s)
    Mass Airflow Sensor Voltage
    Throttle Opening Angle(%)
    Vehicle Speed (mph)
    WGDC
    Logging this many parameters will significantly reduce your resolution, but it should provide some general insight into what is going on.
    2013 Nissan Leaf SL - Extra Leafy
    2002 OBP WRX - Stage II - "Black Betty" - SOLD
    1987 Subaru GL Wagon - Stock - "Mr. Ratburn" - SOLD
    Aug 2011
    Quote Originally Posted by subconfusion3209890
    You say you have a BCS? Is it a 3-port BCS? If so, you won't have a restrictor pill. Also, when you sayI steamed I am assuming you mean smoked. Steam condenses to water..anything viously dI'll t want that in youturbo ake.
    You need to find a way to tome data logs and post them here so that people have a better idea of whats going on. Do you have an AccessPort or a Tactrix cable? If you can, log the following:
    A/F Learning #1(%)
    A/F Sensor #1(AFR)
    Engine Load (g/rev)
    Engine Speed
    IAM
    Injector Duty Cycle
    Mass Airflow (g/s)
    Vehicle Speed (mph)
    WGDC
    sorry for confustion yes it was smoke not steam. Did it again and found nothing even at 20 psi so im sure its not a leak. Secound i have a grimspeed bcs and that t is gone from new hoses. Open for anything new now. Ill post a video of my turbo gauge and see if that helps any.
    WannaBeExpert
    Moderator Donkey's Avatar
    Da boonies,Va
    Sounds like typical boost oscillations. Shorten the wastegate arm a turn or two and see if it still happens.
    2002 FORESTER S
    1998 FORESTER S
    Aug 2011
    Here's a quick look at it
    VIDEO0027 - YouTube
    Da boonies,Va
    Boost ocillations
    2002 FORESTER S
    1998 FORESTER S
    Aug 2011
    [QUOTE=Donkey;321699to Boost ocillations[/QUOTE]
    Really u can see my rpms all that happens within 3-4 grand
    Da boonies,Va
    And that is when peak boost is generally being made then the boost pressure tapers down in the higher rpm. Google "boost oscillations"..........................
    2002 FORESTER S
    1998 FORESTER S
    Registered User Crazyced's Avatar
    Dec 2013
    Ottawa
    Datalogging WGDC will definitely tell you what the ECU is trying to archive boost wise.
    EDIT: You could give this a try:
    http://forums.nasioc.com/forums/show....php?t=1524173
    2004 Subaru Impreza WRX
    2004 Dodge Neon SRT-4
