LOUD Metal on Metal Creaking/Scratching Noise?
Results 1 to 7 of 7
This is a discussion on LOUD Metal on Metal Creaking/Scratching Noise? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Here's a short 30 second video of my snow drifting, you'll be able to here the noise clear as day. ...
    Registered User MisterNBG's Avatar
    Jul 2012
    PA, USA
    Story:
    So I decided to take my 2004 WRX out for a little snow drifting in this snow covered mud/dirt drive way. After a few spins the car suddenly started making a LOUD creaking/Scratching noise. I promise you it was loud because my GoPro picked up the noise over my 3" Catback exhaust. So at the end of the video you'll see me just turning the wheels to see if it was steering related... it wasn't.
    After the video I played with the clutch and all the gears including reverse, No noises, everything was fine, it only happens when the wheels are turning (car is in motion) So I just limped my car home and the noise went away once my car got up to speed (around 30ish MPH). With no garage and a slushy drive way, i'm not planning on crawling under my car today to check it out so I'm gonna ask you Subaru Gurus, what do you think the noise was?
    My theory is that with all the cinders, salt and stones from the snow plows, something might have wedged itself in between my rotors and the brake shield (that thin metal thing behind the brakes, I forget what they're called).
    I hope this is the case, although whatever might have been wedged might have chewed up my rotors, brakes are easier/cheaper to repair than transmission/steering related things in my opinion lol.
    Oct 2005
    Late Devonian
    I concur. I've had that happen before. It sounds VERY much like debri in the brakes.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Yep, that sounds exactly like some sand or gravel lodged in the rotor. I got a small twig stuck there once and it sounded exactly like that. Pulled over, found the twig, removed it, and was back in business.
    Should be easily enough to isolate the rotor and poke the obstruction out.
    2007 Outback 3.0R wagon
  5. #4
    Jul 2012
    PA, USA
    Thanks! I'll have to inspect my brake rotors sometimes soon to make sure the damage isn't too bad.
  6. #5
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    I was barreling down a dirt road and had the same exact noise in my old FX4. I was like wtf, it turned out to be a small branch lodged in the rotor.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
  7. #6
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    power wash your brakes out good
  8. #7
    Oct 2013
    Exactly the same thing happened to me 2 weeks ago. It most likely a rock/gravel that is wedged in between rotor and the shield.
    Sent from my Nexus 4 using Tapatalk
