Exhaust Smoke
Results 1 to 13 of 13
This is a discussion on Exhaust Smoke within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So ever since I've installed my catless dp I've noticed that I have more than normall exahust smoke coming out. ...
    Registered User SUBIE13WRX's Avatar
    Aug 2013
    Buffalo,NY
    Exhaust Smoke
    So ever since I've installed my catless dp I've noticed that I have more than normall exahust smoke coming out. Its not thick white smoke and does not linger, it seems to disapte rather quickly. It doesn't smell like burnt oil just normall exhaust smell maybe fuel if anything. I checked my oil level and was 1/4 qt low 1500 miles into my oil change. I do know that wrx's and sti's do burn oil. So my question is, is this some what normall or may I have a problem, there has been no power loss and I'm using mobil 1 530 aprox miles is 4500 and its also winter time meaning temps are in the 30's so I'm hoping its just the cold weather and not a major issue. I notice it on cold starts and after driving a while sitting at idle though it does go down and is minor. Any thoughts would be healpfull to calm my nerves.
    2013 Subaru WRX OBP, COBB AP, Stage 2 Pro Tune From Innovative Tuning, Invidia Catless DP, K&N Typhoon Intake, Nameless Perforance Axel Back, 300HP Club!!!
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Well for starters, if you are running a catless DP with a cobb OTS map that is not safe.
    Aug 2013
    Buffalo,NY
    Yes I do know that it is meant for a catted pipe well be getting protuned in spring.
  5. #4
    Registered User wrxnguyen's Avatar
    Jul 2013
    714 Orange County
    Could be the residue burning off the new piping. I had that white smoke when I did the q300 catback and invidia catted downpipe.
  6. #5
    Aug 2013
    Buffalo,NY
    That's besides the point anyways, I've had my dp on for 2000 miles and has done it since I installed it. Not sure if its just blow by or what
  7. #6
    It could be smog. Since your car now lacks a cat, it will pollute more and smell worse. This is the main disadvantage of removing a catcon.
    - Al Stewart
  8. #7
    Aug 2013
    Buffalo,NY
    Ya I think I'm all good, I've been watching it everytime I start my car and it seems to be just normal exhaust,
  9. #8
    Nov 2013
    isn't removing the cat illegal?
    If you're upset over someone elses opinions then the issue isn't with the person giving the opinion but rather yourself for taking it personal.
  10. #9
    Nov 2012
    Quote Originally Posted by Justanothername View Post
    Technically modifying your exhaust in any way is illegal in most states.
  11. #10
    May 2010
    Pittsburgh, PA
    I'm not sure why you quoted the message you did, but modifying any part of the emission system (ECU included) is illegal. Replacing the downpipe with a high flow cat is likewise modifying the emission system and is likewise illegal, technically.
    2011 STi Build Log
  12. #11
    Nov 2013
    Interesting
  13. #12
    May 2010
    Pittsburgh, PA
    Interesting
    Yup. You are only supposed to replace the cat with a non-factory replacement is when it is difficult/impossible to get a factory replacement, from what I understand.
    Either way, without a decent tune, OP will be seeing smoke soon enough I bet. Good 'ol overboosting. These GRs are freaking boost machines when you take out the cat.
    2011 STi Build Log
  14. #13
    Registered User Lukhard's Avatar
    Aug 2013
    1. smoke is normal especially if it's cold (obviously). as long as it's not blue or black you're fine.
    2. it's perfectly fine to run an OTS (stage 2) map with a catless DP as long as you don't have a straight through muffler and any other unspecified engine modifications. anyone who tells you otherwise has no professional knowledge.
    3. again, stop worrying about smoke if it's not blue or black. if it's thick white all the time, it could be coolant, then you have problems. doubtful in your scenario.
    source: I'm a race engine calibration engineer.
