Help Identify Oil Leak
Results 1 to 2 of 2
This is a discussion on Help Identify Oil Leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Members, While changing accessory belts in my 2005 WRX I discovered a slight oil leak. It is below the alternator, ...
    May 2013
    Members,
    While changing accessory belts in my 2005 WRX I discovered a slight oil leak. It is below the alternator, front center of the motor. It is getting oil onto the timing belt cover. I have attached a picture. Click image for larger version.
    Aug 2012
    Plover, WI
    It's either the power steering pump or the top of the oil pump. Leaning towards it being the PS pump. I'd wash the area with brake cleaner and run it to find out for sure. Good luck.
