no power steering???? please help!
Results 1 to 8 of 8
This is a discussion on no power steering???? please help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello i have a 02 wrx and i have no power steering in slow tight turns. i checked my fluid ...
    Registered User RallyCulture's Avatar
    Feb 2013
    ATLien
    hello i have a 02 wrx and i have no power steering in slow tight turns. i checked my fluid and its not leaking. i got under the car to look at the rack and pinion and they were no obvious signs of wear or fluid leaks. i looked at the hydraulic pump and again no leaks or signs of obvious wear so im at a loos as far as what to do. the car has about 115k on it. what do u guys thinks it cud be or wat shud i be looking for? wat kind of tests can i do to try to figure this problem out? if its the rack i want to be sure before i go spending 300 and not fix the problem. so if anyone has some expertise on this id great appreciate it thanks.
    Any noises? Is the belt new?
    - Al Stewart
    Feb 2013
    ATLien
    yes its a new belt and its really not noisy at all i can barley hear a faint noise when im in the parking lot really strugglin to turn the wheel.
    If the belt tension is correct check for bubbles coming out the reservoir, and if so bleed. Otherwise I'm at a loss.
    - Al Stewart
    Feb 2013
    ATLien
    so its possible that air can get into the system just randomly even thought it was working fine last week? will i see the air bubbles when the car idles or is this a 2 person job where i need to turn the wheel nd have the other look at the res?
    No it's not possible, and it's a 2 person job. I'm grasping at straws.
    - Al Stewart
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    With that age it could be anything. Air would cause it to make "whining" noises, so that does not seem to be the problem. It's a sprocket type pump, will build huge pressure and has valves "down there" at the rack. If pump is blown or valves are not opening you'd end up with this issue. You could take the return line off and see if fluid comes back. If the return is clogged in the cylinder you would just take that line off and go in with a wire to break up and clean out the crud. But before that, if there is no return flow, check the supply side from the pump. It's possible for the pump to be broken and turn "empty", meaning not actually pumping, only turning. That would require replacement of pump.
    Feb 2013
    ATLien
    ok cool ill def try that and see what happens thank you guys so much!
