Low on coolant
Results 1 to 15 of 19
This is a discussion on Low on coolant within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I have a 2013 bone stock wrx hatch. I just noticed yesterday that I am low on coolant. Oil ...
    Registered User Dustin1232's Avatar
    Jul 2013
    columbus ohio
    Low on coolant
    So I have a 2013 bone stock wrx hatch. I just noticed yesterday that I am low on coolant. Oil is not milky so I don't believe it's a gasket and only get steam out of the exhaust on cold days. I am taking it to the dealer tonight seeing that it is still under warranty. My question is do you guys have any suggestions on where else I should look for a leak? Oh yea and there is no sign of a leak in my garage where it is kept. Any suggestion would be helpful.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Did you check the level in the reservoir when the engine was hot or before starting the car?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Jul 2013
    columbus ohio
    It was before I started the car. It was well below the add line. I'm just a little puzzled. This shouldn't happen on a car with less than 13,000 miles right.
    Aug 2010
    Yonkers/NYC
    What is the level like after the engine is hot? Check on level ground.
    T0ny
    2011 WRX
    2012 FXT
    Jul 2013
    columbus ohio
    I will check it when I get to the dealership after work but I can't imagine it would go up too much if at all. Shouldn't it get lower with it circulating?
    Aug 2010
    Yonkers/NYC
    Coolant expands. So it should be higher when the engine gets hot.
    T0ny
    2011 WRX
    2012 FXT
    Jul 2013
    columbus ohio
    Ok I will check it after driving it and let you know. I hope this is just my paranoia.
    Registered User WRX Piloti's Avatar
    Mar 2013
    How far below the Add line?...it's not uncommon to have to add a bit of coolant and/or distilled water now and then on any water cooled vehicle. You should be checking it a minimum of once a month along with your oil level, brake fluid reservoir level and air pressures. If you are losing coolant but have no visible leak, you may have a small hole in a coolant line/hose and it is evaporating as it leaks out...look for coolant residue.
    Jul 2013
    columbus ohio
    Well put me in a dress and call me Sally. When it's warm the coolant level is right in the middle of the reservoir. I always thought you were supposed to fill and check it when cold.
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Hi, Sally.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
    Jul 2013
    columbus ohio
    Hahahahaha
    Mar 2013
    Quote Originally Posted by Dustin1232 View Post
    Cold it should be between the add and full lines, it should be in your manual...
    Jul 2013
    columbus ohio
    I was actually just going through the manual. It does say to check when cold. It is at the bottom of the reservoir when cold. I guess I will need to have it checked out.
    Mar 2013
    Get some premixed coolant (50/50 coolant & water), add to the full line when cold and see what happens...if it goes down within a couple of days then have it checked out, otherwise it's probably okay...btw, when was the last time you checked the coolant before you noticed it was low?
    Jul 2013
    columbus ohio
    Last I checked it was about a month or two ago. I haven't had the car for that long. But I didn't make it over to the dealership yesterday but I am going to call them today. The manual says that it has subaru's super coolant in it and adding any other coolant or water will shorten the life of their coolant. I would rather not risk any expensive repairs. I will see what they say and let you guys know.
