Boost Leak ?!?!?
Results 1 to 7 of 7
This is a discussion on Boost Leak ?!?!? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; While on the road tuning today, the tuner noticed that car was at full Wastegate Duty and only was making ...
    Registered User KenFerrari13's Avatar
    Jun 2012
    Harrisburg PA
    Boost Leak ?!?!?
    While on the road tuning today, the tuner noticed that car was at full Wastegate Duty and only was making 11 PSI and was tuned for 16 PSI. Leading us to believe that either the turbo was going or there was a boost leak. Anyone know any common places for a boost leak to occur. I thought maybe that BPV was on its last leg or just a leak on one of the lines.
    Car: 2004 WRX
    Thanks Ken
    The tuner didn't have any pointers for you on where to look? Datalogs would give us a good idea on where the potential leak may be.
    Three locations to check are: uppipe, turbo inlet, and BPV gasket.
    Resident Tuner @ WTF Tuning
    Jun 2012
    Harrisburg PA
    Can a cracked inlet cause the car to not hit target boost even though inlet is pre compressor housing?
    Quote Originally Posted by KenFerrari13
    Yes
    Jul 2012
    Rocky Top
    Get it tested or build your own tester if there are no obvious signs of a leak, like a cracked inlet. Then you will know for sure where the leak is or if you have one at all.
    Registered User WyomingWagon's Avatar
    Dec 2013
    wyo
    did you ever get to the bottom of this?
    Dec 2013
    Check your inlet tube from the intercooler to the throttle body. Mine popped off at the throttle body causing the boost to lag and the engine to run rich, leading to backfires and poor throttle response under load. You will porbably have to remove the intercooler to get to the throttle body side though. Worth checking cause it doesn't cost you anything!
