Check engine came on then went away - 14' WRX
Results 1 to 4 of 4
This is a discussion on Check engine came on then went away - 14' WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, So yesterday, I was driving very "spirited" I guess you could say. I was running it pretty hard. ...
    Sep 2013
    West Palm Beach, FL
    Hey guys,
    I was running it pretty hard. I was in 3rd gear, and went to switch gears quickly and accidentally went into 2nd gear. The RPM's went up to about 7,500 before I immediately pushed the clutch back in. The check engine light came on and the cruise control light was flashing. I pulled over, turned the car off, turned it back on and it was still there. It drove fine so I kept going to my destination. However, the cruise control was not working. Anyway, I got to the mall, turned it off, and about an hour later I came back. I turned it on, and the CEL was gone and the cruise control light stopped flashing and worked fine.
    Did the computer just reset itself or something? What happened? Do I have anything to worry about? It is still driving fine with no unusual behavior.
    (yes, I'm an idiot. Gotta be more careful. )
    Thanks,
    Adrian
    Sep 2013
    Montrose, CA
    consider yourself lucky man that you did not blow your engine....... checked for any stored or memorized codes? it would be interesting why did it give you a CEL,,,,,, suspecting CPS that went way way way out of parameterss.....
    good luck
    German Silva
    Registered User CHRISesBUENO's Avatar
    Nov 2013
    Buffalo
    wish i knew, hopefully you atleast did the 1000 break in period method!
  5. #4
    Jul 2013
    Silicon Valley
    Take it to the dealer, it's under warranty. Blow the engine from shifting into too low a gear? More lucky you didn't severely damage your transmission.
    But seriously, it's under warranty, if you're concerned, take it to the dealer.
