Strange noises in 03 STI
Results 1 to 9 of 9
This is a discussion on Strange noises in 03 STI within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi there, first post on the site, what a huge audience that this reaches out to, I must say! Anyways, ...
    Nov 2013
    Wellington, New Zealand, New Zealand
    Hi there,
    Anyways, my parents have recently purchased a WRX STI Sedan, 03 and lately we've been hearing some strange noises.
    Noise number 1: A loud thudding noise as if something is banging around in the boot (which there isn't :P)
    Noise number 2: Regularly cruising around and it sounds like we're driving a plane? Seems like the wheels are letting off some weird, sustained humming noise as if you're taking off in a plane - hope that makes sense lol..
    Anyways, I followed up the loud banging noise with the previous owner and this is how the conversation went:
    [Me] Hey bro, the car makes this strange loud bumpy sound. Back left wheel maybe? Like something is moving around in the boot or something but there's nothing. Any ideas?
    [Him] ohh its not left side its the center back the anti slip diff they make noises under low speed its perfectly fine, i got it checked by jtune when i purchased the car
    , they said its just a noisy diff, koz its anti slip.
    Any ideas on what this could be, team?
    Thanks in advance!
    Ben
    Dampers were known to thud. As for the second noise, rotate the wheels to the front and see if that changes it.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Also get an alignment. Does the thudding get louder around corners and acceleration? If so it could be your axle/boot is shot.
    Registered User 13WRXlimited's Avatar
    May 2013
    Central, New York
    Is the noise from the wheels a constant noise that gets louder the faster you go? If so when was the last time wheel bearings were changed?
    Jul 2012
    Rocky Top
    First Impressions, just conjecturing about.
    Noise 1:
    LSD's can chatter and pop/clunk, although I have no experience with the STi and their diffs. So I don't know how much noise is normal for them. If you find a mechanic who is familiar with how they should sound they'll be able to easily tell if it's normal.
    Otherwise, Axles worn out. bad shifting can cause a thud. struts/dampers, whatever they're actually called. rear diff bushings.
    Noise 2: naturally Loud tires. bad tires. wheel bearings.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Quote Originally Posted by 13WRXlimited View Post
    ^+1 My thoughts too. However, still learning the WRX, but had thumping on both my Jeep, and Ford..... the culprit was bearings in both cases.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Sep 2013
    Montrose, CA
    sounds to me by the description , bad bearings and worn out bushings, my own opinion,,,,
    Registered User Subiefish's Avatar
    May 2013
    Pennsylvania
    I bought an 06 sti about a month an a half ago and i hear the same noise it sounds like someones tapping the side in the trunk, but when the wheels are off everything is tight?! Idk what it is either but yea same problem!
    Sent from my LG-LG870 using Tapatalk
    Nov 2013
    Took it in to the shop, appears to be the tires and axles.. Good answers you guys
