2012 WRX Clutch Pedal Creak
Results 1 to 14 of 14
This is a discussion on 2012 WRX Clutch Pedal Creak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have ~31,000 miles on it currently and the past 5,000 miles my clutch pedal has been creaking. It sounds ...
    Registered User naked_dave1's Avatar
    Nov 2011
    Pewaukee WI
    I have ~31,000 miles on it currently and the past 5,000 miles my clutch pedal has been creaking. It sounds like it's coming from engine bay. It's not a squeak but a creak, and I put some WD-40 on the pedal pivot point and it still happens. My brake pedal also moves a bit to the left when pushing in the clutch.
    I’ve saw multiple threads about this noise. From my searching and watching/listing to other people with this issue I believe I have the same problem of the firewall spot welds breaking. I’d like to get your guys feed back.
    Aug 2012
    Tucson, AZ
    Take off your wiper motor an have someone depress the clutch and watch the welds sway. You'll also see if any are broken yet
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    When my car started doing that, my clutch went. The dealer and myself thought it was at the pivot and lubricated it a few time to no avail. A month or so later I noticed my clutch slipping I am not certain that this is your problem as well, just sounds very similar to mine when it quit.
    '11 WRX DGM
    Nov 2011
    Pewaukee WI
    Quote Originally Posted by nsibanez View Post
    I'll be taking it to the dealer Monday. If they don't find anything I'll give that a try.
    Quote Originally Posted by Kwrxp View Post
    That's not good... About how many miles did you have on your car when it started to happen?
    Aug 2012
    Spring Grove, PA
    Quote Originally Posted by naked_dave1 View Post
    Around 25k miles, sadly. They told me the squeaking was from the clutch breaking down and putting dust into the pivot area. That is why once lubricated, it would clean it out, but start squeaking and groaning soon afterwards. If you want to check you clutch, put it in 5th get the rpms real low and go full throttle. At about peak torque, 3500-4500 area, if your rpms jump and the car doesn't accelerate, you have a bum clutch :/
    '11 WRX DGM
    Registered User WRXilie's Avatar
    Mar 2012
    Riverside, CA
    I believe I am having the same issue, did you ever find out what it was?
    Stage 2 2012 OBP Subaru WRX
    Aug 2012
    Tucson, AZ
    Mines slipping now too. I wonder if the clutch welds have something to do with premature clutch wear
    Registered User wrxmike09's Avatar
    Apr 2009
    Texas
    my 2009 is doing the same thing now. It's a cracked firewall where the clutch is attached. Seems they used some really thin metal in that area. This is a common problem from 2008+ . Of course Subaru denies there is an issue. Doesn't matter if you have a stock or aftermarket clutch, it can still happen.
    Feb 2011
    Elkins Park, PA
    I had this happening on my 08 and the culprit was one of the bolts that holds the pedal assembly to the firewall/under dash area had worked itself loose. tightened it up and all was bueno.
    Josh
    Blue 08 WRX Limited-Cobb AP Stage 2-AEM CAI-Perrin Short throw/bushings-Turbosmart BPV
    Aug 2012
    Tucson, AZ
    Which bolt? If you remember. I'm going to take a look later...even if there's a small chance that it's a bolt and at least help the shifting
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Apr 2009
    Texas
    Quote Originally Posted by wrxmike09 View Post
    Had the dealer check out my problem since it's still covered by the Gold Plus extended warranty. Turned out to be broken firewall welds. At first SOA said they wouldn't cover it but I eventually got to a talk to a manager that agreed it was covered. End result is SOA paid to fix the welds and put in a new clutch and flywheel. This is a common problem on 2008-2010 models. Problem is made worse by use of aftermarket clutches with higher pedal pressures.
    Registered User 19transam81's Avatar
    Oct 2014
    Howell MI
    What is the phone number for SOA?
    Aug 2012
    Tucson, AZ
    I'm wondering if the pressure plate binds on some as well which causes the welds to break?
    Previous cars:
    2009 WRX (sold )
    IG - kevinrimcoski
    Registered User Zitro's Avatar
    Jul 2013
    Seattle, WA
    Sorry to bump a hella old thread, but I am having this EXACT same creak, just started last night :/ 2013 WRX, 30k miles. Was the firewall weld issue resolved after the 2010 model year and my issue is likely just one of lubrication, or is it possibly the firewall welds going? If it's the firewall, I'm sure SOA would use my light mods to deny warranty work...
    **Stink-Eye Mob Member #96**
    2013 Rex Hatch Rally Blue
    Crying over money spent on this car and my obsession with hi-fi/ audiophile goodies
    "I would buy that car if I was the sort of person who looked at my sister and thought, mmmmmm." -Jeremy Clarkson, referencing the Ford Mustang
