Where do I start checking for damage
Results 1 to 11 of 11
This is a discussion on Where do I start checking for damage within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; WRX14-My buddy this weekend miss shifted.from 3rd to 2nd freeze frame shows all data when the cels went off. I'll ...
    Oct 2013
    WRX14-My buddy this weekend miss shifted.from 3rd to 2nd freeze frame shows all data when the cels went off. I'll post the logs after work. The engine revved to 7400rpm. The codes were reset and the car was brought to subaru and they say nothing it's wrong with it and everything is still under warranty. The car seems to have powerloss after the mishap. Can any one give us some advice as were we should start.looking for damange. The codes that went off were p0341 and p0346.
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    It may still be under warranty, but if something were to be damaged from a driver error like this, I do not believe the warranty claim for any damage done will be accepted by Subaru.
    Oct 2013
    Subaru has no.idea what happened to the car they think it was wiring close.to the sensor. Subaru cant find any damage. I'm.sure they didn't look but my.buddy doesn't want the motor to detonate.maybe to bad time. Something tells me that he might have jumped a tooth. Boost is at ,13 so that's normal.but in fifth gear when you wot the revs go up and down.myb 300rpm when the boost kicks in
    Sent from my SPH-L900 using Tapatalk
  5. #4
    Oct 2013
    If you over revved the motor and got codes p0341 p0346 where should you start looking for damage.
  6. #5
    Registered User atranz's Avatar
    Aug 2012
    houston, tx
    I did the same thing in my rsx type s. My tach needle went in a 360 motion. It started to dirve bad like a bad valve job. I took it in to acura and they adjusted the valves and cleared the ecu. The car ran great for 1000 miles then I dropped a valve. Acura end up replacing the motor (long block).
    Good luck with everything.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  7. #6
    Palmyra, NJ
    Didn't you post about this already the other day?
  8. #7
    Oct 2013
    Different questions. Im trying to find.out where I should look for damage
  9. #8
    Palmyra, NJ
    datalog the car.
    Or pull open the timing belt cover and look at the cam gears? Or pull the engine out and inspect the valves?
    Or reset the ECU and see if it relearns fueling and improves over the next week or so.
  10. #9
    Jul 2012
    Rocky Top
    +1^
  11. #10
    Oct 2013
    Ecu has been.reset already. I do have freeze fram data at the time cel was thrown. I will upload those screen shots once I get home from work.
  12. #11
    Oct 2013
    Freeze frame data
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1383757796637.jpg   uploadfromtaptalk1383757811677.jpg   uploadfromtaptalk1383757863003.jpg   uploadfromtaptalk1383757884367.jpg   uploadfromtaptalk1383757895762.jpg
