Removing studs from snow tires.
Results 1 to 2 of 2
This is a discussion on Removing studs from snow tires. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just a quick question, I know you can easily remove the studs from the snow tires, WD40 needle nose pliers ...
    Registered User SDub's Avatar
    Feb 2013
    Just a quick question, I know you can easily remove the studs from the snow tires, WD40 needle nose pliers and elbow grease.
    I found so one seasonal use on some tires locally, used on a 335 xi. But they're studded. I don't like the loud noise on the road when it's not snowing and I dont think i need the studs for the awd wrx anyways.
    Is it ok to just remove them? And proceed as usual?
    Any help will be appreciated thanks.
    Sent from my Fone
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I have studdable General Altimax. Bought them without the studs. So it shouldn't be a problem if you take them off. You should probably also check for punctures once you take them off.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
