Need Help Diagnosing
Results 1 to 15 of 22
This is a discussion on Need Help Diagnosing within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am having an issue with what seems like my turbo, or something connected to it. Stock 09 wrx turbo ...
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    I am having an issue with what seems like my turbo, or something connected to it. Stock 09 wrx turbo setup, with a catted dp and stage 2 tune. I am having an issue where I can hear the turbo fan spinning, like a lot. It is consistent with RPMs and road speed, not necessarily boost pressure. When I take my foot off the accelerator and clutch in, is when I hear it the most (as the RPMs drop off to idle). It sounds like the fan is just spinning under its own momentum. I first thought it was due to one of the bolts, connecting IC to turbo, being loose, due to stripped threads. Dealership helicoiled the threads and the IC is secured now. Noise still happens
    My plan is to hook up a tactrix cable this weekend to see whats going on. According to my butt dyno, the car is still boosting well and driving normally.
    Also, I know exhaust gasses pass through the turbo constantly, right? When letting off the accelerator, does it normally spin under its own momentum to idle speed or does something control its slowing down?
    Ideas?
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: Torqued Performance Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
    Registered User cmayba's Avatar
    Feb 2013
    Upstate NY
    Throw out bearing?
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    The pressure built by the turbo will also slow it down once the exhaust gas reduces. The turbo doesn't have a fan, its a turbine driven by exhaust gas and on the other side (compressor) the shaft drives the air into the intake and build pressure. This same pressure will keep the turbo from spinning any faster and slow it down once the exhaust gas pressure is down. There are things like stalling, but I'm not all that familiar with the specifics.
    Oct 2009
    Dirty Jerz
    Quote Originally Posted by cmayba View Post
    Throw out bearing?
    Just replaced/fixed
    Quote Originally Posted by Ingo View Post
    Yea, turbine (thats what I meant by fan). So once I let off the throttle, the pressure built up should slow it right down?
    Zach
    Stink eye Mob #287
    Palmyra, NJ
    Get a TDI. It will solve all problems.
    Jan 2012
    Philly Area
    Bro...does your turbo even variable??
    - Will
    Oct 2009
    Dirty Jerz
    Anyone?
    Sent from my iPwn
    Zach
    Stink eye Mob #287
    Palmyra, NJ
    Quote Originally Posted by spirited09wrx View Post
    Anyone?
    Sent from my iPwn
    Honestly buddy...just like we tell other n00bsauces around here, you can't really diagnose a sound through text. I've kind of heard it in person, but I'd have to hear it again since it's been awhile.
    Oct 2009
    Dirty Jerz
    Just thoughts of things to check in that area or maybe someone had the same issue
    Sent from my iPwn
    Zach
    Stink eye Mob #287
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Pull your DP and see if there is any shaft play in the turbo.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    Mar 2012
    IS it actually a "sirring" noise coming from spinning turbo or is it more a whistling noise coming from a leak? A leak seems to be more likely. Removal of downpipe should be easy and allow to check the mechanical condition of the turbo's bearings, as Drews stated above.
    Oct 2009
    Dirty Jerz
    Not a leak. It's def a spinning type noise. Spin it reallllly fast and just let it slow down on its own momentum.
    Sent from my iPwn
    Zach
    Stink eye Mob #287
    Mar 2012
    Do you have the original bypass valve and is it working correctly? You probably need to get yourself some Tactrix and laptop and/or ELM Bluetooth with Torque software on your phone and get actual boost numbers...
    Oct 2009
    Dirty Jerz
    Yea, only engine mod is exhaust and tune. I am grabbing mikie'a tactrix in 10 min and I will mess with it tomorrow.
    Sent from my iPwn
    Zach
    Stink eye Mob #287
    Oct 2009
    Dirty Jerz
    Mikie sat shotty for a bit. He says it's my transmission.
    Sent from my iPwn
    Zach
    Stink eye Mob #287
