Help! fuel pump doesn't prime. nothing :( - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
This is a discussion on Help! fuel pump doesn't prime. nothing :( within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Update, Started unplugging all the harness under the hood on my car. Turn ignition switch to on position. Tada, the ...
  1. #31
    Registered User flytime's Avatar
    Jul 2013
    Wisconsin
    Update,
    Started unplugging all the harness under the hood on my car. Turn ignition switch to on position. Tada, the fuse doesn't pop. Work my way backwards. Found out there's a short somewhere on the manifold wires. Because when I plug the brown harness in by the battery, it pops the fuse.
    04 Impreza Wrx
  3. #32
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Alright, sounds like you're on your way. Good luck going forward.
  4. #33
    Jul 2013
    Wisconsin
    Quote Originally Posted by Ingo View Post
    Found the short on my injector wires. Cut and butt connected it along with electrical tape. Starts like a Champ!
    Thanks for the input and everything!!
    04 Impreza Wrx
  6. #34
    Mar 2012
    Cool. Thanks for reporting back, so many people don't. Now where and how exactly did that happen? Is the fuel pump supply routed together with the injector wiring or was the short actually in the injector wiring and that's just on the same circuit?
  7. #35
    Jul 2013
    Wisconsin
    How it happen - When I put the sti pinks in, I routed the injector wires the wrong way so the wires was rubbing against the manifold, the red (positive) in particular. It cut through the wire. Sorry I don't know how to explain. If only I can post pictures but I'm at my limit. And yes it's on the same circuit.
    http://i69.photobucket.com/albums/i5...ps2a77d36b.jpg
    04 Impreza Wrx
  8. #36
    Mar 2012
    Thanks, this will probably help someone in the future.
