Two new problems.
Results 1 to 5 of 5
This is a discussion on Two new problems. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've recently started modding my 11 hatch wrx. I was openEcu TP stage 2 with just a catted TurboXS dp. ...
    Registered User i8yourV8's Avatar
    Aug 2003
    new york
    Two new problems.
    I've recently started modding my 11 hatch wrx. I was openEcu TP stage 2 with just a catted TurboXS dp. It ran perfect, but I have no gauges so I went with the Accessport v3. I still went with TP stage 2. Now I started getting the low dipping idle at or coming to a stop with the Accessport hooked up. I unplugged the Accessport and no more idle issues. Next I bought a Magnaflow cbe which drones horribly at any speed with the gas peddle down. I'm getting a vibrant 12 inch resonator put in this week to see if it helps. No leaks under the car either. I'll keep everyone posted.
    Loving my Stage 3 TP 11 WRX hatch
    L.I.S.C #6
    May 2007
    orlando flawduh
    how long did you have the idle problem? usually once you flash a map with the accessport it will take a day or so for the ECU to re-learn everything and your idle will be wonky for a little bit. this happened when i flashed from my protuned stage 2 map back to my OTS stage 2 map
    desiree
    Registered User WREXXY's Avatar
    Oct 2012
    CT
    You could always try upping the idle set point on the AP. I don't know which is the master/slave setting in regards to the ap and the specific tune u have loaded. But I could see the ap being the master while it is plugged in. Email Eric with the idel setting on the ap and ur issues and he should be able to explain it more
    Aug 2003
    new york
    Its been flashed for two weeks now, ill plug the Accessport back in and let yall know.
    L.I.S.C #6
    Palmyra, NJ
    The Magnaflow is known to be horribly tinny and droney sounding on the hatches. One of the reasons why it's such a cheap exhaust compared to a lot of the others.
