HELP ME!!!
Results 1 to 7 of 7
This is a discussion on HELP ME!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2005 WRX wagon 2.0l turbo. The car will not start. Im getting spark but it's not consistent. ...
    Nov 2012
    HELP ME!!!
    Im getting spark but it's not consistent. You turn the key and it just turns over. I just
    Put a new battery and had a new short block and remanned
    Heads. I also replaced the camshaft sensor. I have had it a two different dealerships and
    No luck. Please help me figure this out.
    Thanks,
    Has someone verified fuel pressure?
    Nov 2012
    Someone has checked the fuel pressure. It's fine. Everything leads to the spark.
    Palmyra, NJ
    Coilpacks done? Plugs done? Comb over everything having to do with the electrical system. ECU bad?
    Nov 2012
    The coilpacks have been checked out along with the spark plugs and all the electrical conponance.
    My mechanic thinks it's the ecu has to be programmed. We tried three different ecus and they all had the same problem.
    I hope you can think of something else it may need.
    Thanks,
    Marc G.
    Jul 2012
    Rocky Top
    Did you check your fuses?
    The ECU will run a stock car correctly. Is your car stock?
