Extremely Confused - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on Extremely Confused within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I already have a tial mv-s ewg and yes i did feel that sudden lack of power. I was shifting ...
    Registered User SubiesaurusWRX's Avatar
    Sep 2013
    Colonia
    I already have a tial mv-s ewg and yes i did feel that sudden lack of power. I was shifting hard from 3rd to 4th. Target boost is 18.5 psi, but, at the time the AP read 19.8 psi when it happened. I dont have access to adjust the cycle myself and if i do idk how. Im new to subarus and i bought the car with all my mods on and tuned already. I cleared the code and reflashed the ecu with the same tune. Can this have anything to do with my wastegate spring at all?
    2011 WRB WRX: DW 850 cc injectors. FMS tmic. Custom SRI. GT spec header. Maddad Turboback. Tial mv-s ewg. Perrin Recirc Valve. Grimmspeed ebcs, crank pulley, and up-pipe. Cobb AP w/ custom tune. ACT HD clutch w/ lightweight flywheel. StopTech Club Kit ( front). Whiteline 3-pt adj. sway bars f/r. Perrin front endlinks. Drag DR31 wheels 18x9 +15 offset. Nitto NeoGENS UHP all-seasons. Ultra Racing Rear Strut Bar.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by SubiesaurusWRX View Post
    I suppose anything's possible, but it's not likely.
    Sep 2013
    Colonia
    What is the more optimal solution to fix/avoid this problem again? Is there a possibility of this happening again if i push harder even the slightest bit. Im a very spirited driver and i wouldnt want this to be a reoccurring thing everytime i wanna have alittle fun.
  6. #19
            MainFrame's Avatar
    Austin, TX
    Retune the car.. that's by far the best solution for overboost when it's not caused by a mechanical problem. A competent tuner should be able to fix the problem in less than 5 minutes if you can show them a log of the event. Although it seems a little odd that it would overboost at the top of 3rd. Usually overboost like you're describing will occur if you floor the car from low rpm in a higher gear, like 4th or 5th (which you just shouldn't be doing anyways).
  7. #20
    Sep 2013
    Colonia
    [QUOTE=MainFrame;3146826]Retune the car.. that's by far the best solution for overboost when it's not caused by a mechanical problem. A competent tuner should be able to fix the problem in less than 5 minutes if you can show them a log of the event. Although it seems a little odd that it would overboost at the top of 3rd. Usually overboost like you're describing will occur if you floor the car from low rpm in a higher gear, like 4th or 5th (which you just shouldn't be doing anyways.)
    Mechanically everything is sound, unless the first incident cause unknown damage. But i was running some logs and i did notice that flooring it from low rpm to high in fourth does cause the issue. I felt the car about to cut again but i released the gas and when i viewed the log, target boost is 18.5 and i hit 19.8 several times. And my last question is what is considered overboost, more than 2 psi over target? Idk what my limit is but since the cold weatherweather came in its been a more frequent occurance.
