HELP!! Oil leak.
Results 1 to 8 of 8
This is a discussion on HELP!! Oil leak. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2012 WRX sedan and discovered some oil leaking under the engine bay. The leaks appeared very minor ...
    Registered User DwnShft4WRX's Avatar
    May 2012
    NorCal
    HELP!! Oil leak.
    I have a 2012 WRX sedan and discovered some oil leaking under the engine bay. The leaks appeared very minor but they still concern me.
    The first leak was the larger of the two. The follow 3 pix and 1st vid shows what's going on. I'm trying to figure out where the leak is coming from and how to address it. Any input is appreciated. The 2nd vid shows a very minor leak at the oil temp sensor thread on a sandwich adapter. I'm just going to try and tighten the sensor in more but any input on that is appreciated as well.
    If there are previous threads or stickies that I may have missed regarding these issues, I apologize; please link the appropriate threads.
    2012 WRX Unknown Oil leak - YouTube
    https://www.youtube.com/watch?v=dNd3OQYNj_0
    When life passes you by, DownShift! - DSC
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    I would bring it to the dealer, you have a 2012 use that warranty.
    May 2012
    NorCal
    I've already considered that. However, I'm modified so...you know how that goes.
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    The underside of your car is fantastically clean. My engine has small oil leaks (from what I think are the breathers above the heads), but I don't let it bother me since I regularly check my oil level. Do you know if your oil temp. sensor was meant to be installed with some kind of lubricant (like PTFE tape on a tapered thread) or gasket?
    David - '05 WRX
    May 2012
    NorCal
    I do over the top maintenance on my car and I guess it shows. I also regularly check my oil and all fluids for that matter; all levels are prime.
    To my knowledge, my oil temp sensor was to be installed as is; no lubricant, sealant or gasket. I have the Defi Racer oil temp gauge.
    I'll check the under side of my engine bay in a week or two and see if the oil leak returns. In the meantime, I have no clue what to fix or if there is anything that needs to be fixed. All I know is that a leak is not good.
    Do you recall where your oil leak was coming from? Was it the same area as mine? Is it supposed to be leaking or was something loose or broken? Thanks for any input.
    Oct 2011
    Santa Ana, CA
    Dealers know people buy Subarus to modify them. That said, ask them straight out if they are mod friendly.
    Dealer #1 near me is totally mod friendly, they service Subies with built engines and all. Dealer #2... not as friendly, basic mods ok.
    Unless they can prove your mods caused the damage, you're ok.
    May 2012
    NorCal
    Guess I'll give the dealer a call and see where they stand regarding mods.
    May 2012
    NorCal
    Update. My experience at the dealership was, not surprising, horrible. But all that aside, I'll just get straight to the point. The service techs removed the throttle body to intercooler hose and replaced it with the same, but new, throttle body to intercooler hose.
    The techs says that it's "normal" for a brand new car designed for performance to be leaking oil like it is.
    After my dissatisfying experience at the dealer, I came home and wrote a complaint letter to SoA. I doubt they will care but whatever. Needless to say, I will not be going to that dealer anymore. From this experience, I prolly don't care about the factory warranty now either.
    Thanks everyone, for your input.
