ODD CHARGING PROBLEM....
Results 1 to 3 of 3
This is a discussion on ODD CHARGING PROBLEM.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So yesterday on my 03 wrx I noticedmy lights dimming, radio shutting off, guages, abs light, etc. No battery light ...
    Sep 2013
    So yesterday on my 03 wrx I noticedmy lights dimming, radio shutting off, guages, abs light, etc. No battery light though. Then I pulled the fyse out in the engine bay fuse box labled ALT-S its a ten amp fuse. When I pulled the fuse, it started charging again, but my battery light and my brake light came on. I put a volt meter on it and it was charging to high.. about 15.4v. The battery is brand new and it is good. Any ideas??? I'm assuming its a bad alt but the fact that it charges with the fuse out but not in baffles me....
    Quote Originally Posted by CalebJ View Post
    Then it wasn't charging. You can't have it both ways I don't think. If BAT and BRAKE are on, the system is losing charge, not charging.
    I'd suspect the alt or v regulator, which is built in and not worth replacing individually anyway -- so I'd be back at the alt and have that tested.
    Palmyra, NJ
    Alternator. Get that tested to tell you if it's good or not.
