2004 Subaru WRX Clutch issue
Results 1 to 9 of 9
This is a discussion on 2004 Subaru WRX Clutch issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay so I've scoured the interwebs for a while now and it seems to me that i'm THE only person ...
    Registered User MisterNBG's Avatar
    Jul 2012
    PA, USA
    Okay so I've scoured the interwebs for a while now and it seems to me that i'm THE only person on this planet with this problem, either that or I describe my problem differently in the search engine and Google won't find what I'm looking for... Which is answers.
    Here's the problem, when pulling out, usually around 0-5 mph I slowly let off the clutch, slowly push in the gas and my car shakes, my 3" exhaust rattles on the underside of my car, everything just shakes, violently! But once the clutch is engaged, it's fine! No slip, it's fine in 2nd, 3rd etc etc. Just when I'm pulling out it does this, actually it does it in reverse sometime too, but not as often. Also this problem seems to get worst as the clutch gets warmer, on my way to school it doesn't really do it, but on my way back it's terrible!
    So I've been experimenting, I've asked myself, "is this car really that touchy?!" So I gave it more gas than I would other MT's I've driven, that kinda solved the problem but this involves a lot of clutch wear after time and I feel pulling out @ around 2k to 2.5k rpms shouldn't be the solution to my problem, I've tried letting the clutch grab before giving it gas and then once the RPMs start to drop, I give it gas.... This didn't work... So WTF is this things problem?! I'm not new to MT cars, I know this is AWD and that AWD cars are a bit more touchy than FWD or RWD cars, but still what gives?
    I bought the car a year ago, the owner claimed it had a new clutch replaced about 15k miles ago, so I'm wondering if possibly he or who ever put the clutch in, did a ****ty job? Maybe didn't align **** up right? idk...
    What should I do? Is this common? Should I just take it to a garage or a Subby dealer and have them look at it?
    Because honestly it's embarrassing, it's like the entire engine, transmission and driveshaft are shaking around while my exhaust pipe is rattling about making all this noise, people at school are looking at the car and then hear/see all that **** going on and it looks like I don't know WTF I'm doing lol!
    PLZ help!
    It sounds like a grabby clutch, or clutch chatter. Since you don't know which parts are installed on the car though I can't say anything more.
    Jul 2012
    PA, USA
    Yeah I'm not sure what was all done to it while they changed the clutch, so should I just take it to a garage or a Subaru dealer?
    I don't actually think there's anything wrong with it. You could go to a garage and ask them to make sure the gearbox mounts are securs, and the bolts mating the gearbox to the motor are secure, plus check for play in the driveline. Other than that, it sounds like an annoyance.
    Subaru delivered cars with a grabby clutch in 2002 and then had a voluntary recall. I got my clutch changed at 30K miles for free as a result. They installed a different clutch and a heavier flywheel and the chatter was gone. I'd not pay to have it done though out of pocket, not worth it to me.
    Jul 2012
    PA, USA
    Okay thanks, you're very helpful! I'll do that then, in the mean time, any idea how I can minimize the clutch chatter? Do I lack a certain precision this clutch is requiring? lol
    Quote Originally Posted by MisterNBG View Post
    In my case, it was a combination of heat, throttle, and luck.
    Palmyra, NJ
    Do you know if it has an aftermarket clutch?
    Also, what exhaust do you have? Some of them out there actually can rub against the driveshaft causing a lot of noise, especially if there is a lot more vibration from loose mounts.
    A 2004 with how many miles? Cause the mounts themselves could be wearing out...the stock ones are only rubber.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Sounds like possible flywheel alignment. When he did the clutch did he mention flywheel resurfacing, or getting a new flywheel. Based on school of hard knocks If I do a clutch I do a flywheel as well. Just my experiences
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    I know I always hate the added expense when I've already paid for a clutch kit but I end up doing the same too, you're right. Some people only do the disc, I can't imagine that when everything's apart anyway.
