clutch issue.
Results 1 to 7 of 7
This is a discussion on clutch issue. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 04 wrx .....put a new engine in it....when you turn the pully in the front manually back ...
    Jul 2013
    clutch issue.
    I have a 04 wrx .....put a new engine in it....when you turn the pully in the front manually back and forth it makes a scrapping noise in the clutch..is it ok or is something really wrong. Plz helpp
    Registered User Turbo_Tuner's Avatar
    Aug 2013
    What makes you think it is in the clutch? If it is something in the clutch it is probably just your throw out bearing making noise against the pressure plate because the WRX's have a pull style throw out bearing.
    Jul 2013
    That's what were thinking it is
    Feb 2010
    SL,UT
    Did you replace your clutch when you replaced the engine?
    Hawk-Eye Alliance #801
    Jul 2013
    NO
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Well, something is really wrong. That's just fact. Now, you didn't change the clutch, ok. But did you have it apart to inspect for wear? That should be at least done. Only if in very good condition would I leave that clutch in there. Nothing worse than doing stuff over again. SO if you had it apart, is there a chance you might have put the plate in the wrong way? Or the throw-out bearing (doubt that can even be reversed...) or the throw out lever could have gone "off the rocker"...
            MainFrame's Avatar
    Austin, TX
    I would replace the TOB every time it's apart, just cause.
