brown coolant?
Results 1 to 11 of 11
This is a discussion on brown coolant? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My coolant keeps turning brown but no oil in it. What could be causing it? I flushed it about 4 ...
    Nov 2011
    brown coolant?
    My coolant keeps turning brown but no oil in it. What could be causing it? I flushed it about 4 times but it keeps turning brown. At the bottom when I drain is this red liquid that comes out. Once again, it's not oil. what could cause that?
    07 Wrx 100k miles
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    Rust? Did the car sit for a long time?
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    Red? Is you car a automatic? Tranny fluid from the cooler in the radiator maybe. Be low at the dip stick and tranny fluid show a slight pink haze if so.
    Really hope your car is a manual!
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
  5. #4
    Nov 2011
    manual, at first it was rust but now it looks like bars leak or something. I don't have any leaks or anything
  6. #5
    Corrosion is cheaper than the other alternative, combustion fluids.
    - Al Stewart
  7. #6
    Nov 2011
    I hope it's just that and not combustion
  8. #7
    Jul 2013
    North Carolina
    Compression test time...best of luck
  9. #8
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Could also be corrosion with in the engine it's self. But a 2007 seems kinda new for that. Unless there was a poor coolant mix somewhere along the line, i.e. to much water ????
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
  10. #9
    Nov 2011
    could the gasket on the turbo be a culprit?
  11. #10
    Anywhere the coolant could meet either atmosphere, oil, or a combustion fluid can be a potential culprit, yes.
    - Al Stewart
  12. #11
    Nov 2011
    GOOD NEWS EVERYONE! I did an engine block test with that engine block test liquid to check for exhaust or combustion fumes in the coolant system. It stayed blue the whole time. Better news its not oil, I used distilles water and its not separating.
    Further investigation shows, my coolant system is clogged up with bars leak. An abnormal amount. The only people who have touched this car are my mechanic and myself. I would never use a quick fix tool or anything as such to get around any problem. I never had a problem the car is still
    healthy. Now the only other person to touch my car is my mechanic at a performance shop. Hmmm...
