Short Throw Shifter and "banging" sound
Results 1 to 9 of 9
This is a discussion on Short Throw Shifter and "banging" sound within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, Short Throw Shifter Question: I'm not sure if this is normal as I don't have much prior experience ...
    Registered User Brandi's Avatar
    Jul 2013
    Maryland
    Exclamation Short Throw Shifter and "banging" sound
    Hi all,
    I'm not sure if this is normal as I don't have much prior experience but there seems to be a slight resiliance going into 1st, 3rd and reverse. Not all the time, only once and awhile. FYI: It's not operator error. Lol. It has never not gone into the gear, but as I've gone to put the shifter knob in, it "struggles". Instead of forcing it, I usually will pull the knob back to the center and retry. Then it goes in without resiliance. (Wow, that sounded kinky). LOL. Anyway, anyone else have any suggestions or opinions or experience with this?
    Banging sound:
    It occures when the car has sat over night, etc (not if I just go into the store). As I release the emergency brake, put into 1st, and drive, within 10-20 feet there is a "bang" or "pop" sound. Almost as if a disc is not releasing and releases upon driving. Again, suggestions, opinions, or experience?
    Thanks you,
    Brandi
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    1.Avoid going into first when the car is in motion.
    2. You will soon enough learn the Subaru dance. Reverse is always a hassle. If the gear refuses to engage, just put it back into neutral & try & try again.
    3. The noise you hear when the car moves after having been parked is hill assist disengaging. Nothing to worry about.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Jul 2013
    Maryland
    Thanks Rage. I grew up in a muscle car family, thus I learned early on to never engage 1st gear until stopped. I also do this with reverse. Old habits never die. ;-)
    Thanks again for the information.
    Brandi
    Purchased 7/17/13: 2013 WRX Limited- satin pearl white: short throw shifter,Perrin quad tip cat-back
    Registered User SomeGoalie's Avatar
    Jan 2013
    Cleveland
    Did you get the factory short throw or did you install aftermarket?
    If you did the install you might have over tightened the bolt that goes through the shifter pivot. I did this originally and it made shifting a little difficult. Loosening the bolt fixed the issue for me.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Are the short shifters more prone to engagement issues then standard shifters....seems so based on the posts I've read ???? Mine engages in all gears smoothly, maybe not super crisp, which is why I've been thinking about a short shifter. Thoughts ?????
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Jan 2013
    Cleveland
    Quote Originally Posted by cogito View Post
    I have zero problems with my Kartboy since I properly tightened it. Shifts nice and smooth.
    Jul 2013
    Southern NH
    Quote Originally Posted by SomeGoalie View Post
    Thanks. I have zero issues with the stock standard shifter, with the exception of a little more precision. So the kartboys are pretty crisp I assume. Since you seem pretty happy
    Jan 2013
    Cleveland
    Yeah I've been enjoying it. I have an Anarchy Motive shift knob and the pivot bushing installed with it. Still need to install my front and rear shifter bushings.
    Jul 2013
    Maryland
    I purchased the short throw from Subaru thus it was installed prior to purchase. When I take it in for it's first service, should I have them check it just to be safe? Or just assume, this in normal for the short throw?
    Brandi
