90K miles Burning OIL?
Results 1 to 15 of 22
This is a discussion on 90K miles Burning OIL? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm here again back in the forum to sick help and insight regarding my cars issues. I just changed my ...
    Registered User MrSubielove's Avatar
    Aug 2010
    I just changed my oil about 800 miles ago, yesterday I checked the dipstick and it was already on the LOW tick mark, I don't see any oil leaking from under anywhere. I've read a thread regarding turbo engine being normal to burn oil, but I'm highly concern due to the bad stuff that happens due to oil starvation. What do you think i should check on my car, I don't see any smoke anywhere, no smell either.
    I use Mobil 1 full synthetic.
    Oct 2011
    Santa Ana, CA
    Like many others my Subie would burn M1 like crazy. I use a heavy duty diesel oil now.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Any smoking ???? Thinkin rings....
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Aug 2010
    no smoking
            MainFrame's Avatar
    Austin, TX
    I would use something thicker and see if that helps.. Mobil 1 5w-30 shears like a bitch in turbocharged engines.
    Jul 2013
    Southern NH
    You might try seafoam. I've used it for carbed engines, but not turbos... So don't know.
    Aug 2010
    what do you suggest? 5w-40, I live in texas
            MainFrame's Avatar
    Austin, TX
    Yeah.. 5w-40 is within factory spec for our climate here in TX. I use Rotella T6, seems to hold up well in the hot weather. There is also Mobil 1 10w-40 synthetic, which performs much better than their 5w-30 in UOAs.
    Aug 2010
    I will try that, what's the chances of blowing the engine for using a thicker oil?
    Aug 2010
    I'm also concern about the thick oil going through the turbo, I wonder is such viscosity could cause leaks and performance concerns.
    I don't understand what that statement means. The viscosity works fine in our cars.
            MainFrame's Avatar
    Austin, TX
    Mobil 1 5w-30 is already pretty thin.. after about 1000 miles it's down to 5w-10 and doesn't lubricate near as well. A 5w-40 or 10w-40 will coat things better, provide better lubrication, maintain higher pressure, and be less prone to shear.. I would say the chances of blowing an engine are a good deal less when running a thicker oil, especially with all the engine failures already linked to Mobil 1 5w-30.
    Also, if it's thicker it is LESS likely to leak.. hence the recommendation. If you're pushing oil past your rings then a thicker oil should at least help alleviate some of the consumption you're seeing.
    Aug 2010
    Alright, I will upgrade to a thicker grade.
    Aug 2010
    Oh, im not a car guru and just concern of having engine issues that thicker might cause.
    Where was the level when you first changed it?
