Wheel bearings
Results 1 to 11 of 11
This is a discussion on Wheel bearings within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 03 WRX that needs a new wheel bearing. I know they are a pressed bearing. Is there ...
    Registered User Bumblebee92's Avatar
    Dec 2012
    PA
    Wheel bearings
    I have an 03 WRX that needs a new wheel bearing. I know they are a pressed bearing. Is there any easy way I could change this at home with normal house house tools?? I have gotten quotes anywhere from $300-$500, and not really wanting to pay that if its possible I could change it myself.
    Any advise will help. Thanks.
    Jan 2012
    Philly Area
    I feel like I remember someone on here recently doing this job at home. IIRC they had to fabricate a special tool.
    - Will
    Jan 2012
    Philly Area
    Bingo. Subaru Wheel Bearing How-To / FAQ | RSM Innovation Not what I was thinking of but anyways, there it is. Obviously it's not the same car but gives you an idea of what you'd be in for.
    For the record, my memory was wrong. Sad Panda. I was thinking of 06wrx4me's ball joint removal thread.
    - Will
    Dec 2012
    PA
    Thanks a bunch!!! Will surely use this tomorrow when in changing it
    Jan 2012
    Philly Area
    No problem, good luck!
    - Will
    Moderator Donkey's Avatar
    Da boonies,Va
    Big thing to remember is the 2 inner seals go in backwards. You will find out you forgot this when the CV axle won't go back in
    2002 FORESTER S
    1998 FORESTER S
    Dec 2012
    PA
    Is it possible to take the housing off with the bearing still inside. And my repair manual says I need to take out the rear axel .... Is this true ??
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    By housing do you mean the upright? If so then yes, you can remove it with the bearing inside. The axle is inside the bearing so it at least has to come out of the upright so you can use your bearing puller. You can leave the diff end if you want.
    Some people remove the uprights and take them to a shop to have the bearing pressed in. I've seen $60-80 to do a pair but I'm sure prices vary.
    Dec 2012
    PA
    If that's the part that keeps the bearing in place, then yes. So I can just take the upright off and not touching the axel?? If I can then it would really be some great news to hear. I'm on an extremely tight time crunch for the next few days
    Jun 2010
    Colorado
    The upright is the heavy cast iron part that the bearing is pressed into. You will have to remove the axle nut, the trailing arm, and likely at least 2 of the lateral links in order to pull the axle out of the hub. The end of the axle that goes into the rear diff can stay in the rear diff.
    No matter how you do it, at the wheel end the axle nut has to come off and the axle has to come out of the hub.
    Dec 2012
    PA
    That's what I thought and wanted to hear. Thanks a lot. Thanks to everyone who helped out. It's more than appreciated
