Oil Level
Results 1 to 8 of 8
This is a discussion on Oil Level within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2013 WRX with 3000 miles on the original factory oil. I plan on getting my first oil ...
    Registered User cmayba's Avatar
    Feb 2013
    Upstate NY
    Oil Level
    I have a 2013 WRX with 3000 miles on the original factory oil. I plan on getting my first oil change this Friday and was curious as to what the oil look like and where the level was. It was about an 1/8" above the full hole on the dip stick (right at the bottom of the twist on the dip stick above the full hole). Now i'm kind of worried there was too much oil and hoping it didn't do any damage. Too much oil is just as bad if not worse then no oil, right?
    Feb 2013
    Upstate NY
    ..and yes car was on a level surface and had been off for about 5 hours. I wiped the dip stick clean then dipped it for the reading.
    [QUOTE=cmayba;3036498Too much oil is just as bad if not worse then no oil, right?[/QUOTE]
    No. Low oil is worse than high oil.
    You should be checking the oil level routinely though.
    Registered User wrx frog's Avatar
    Jul 2013
    Make sure the dipstick is oriented the right way. I was told for my 06 sti that the dipstick enters the oil at an angle so one side will be higher than the other. I don't believe that has changed.
    Registered User garzdos's Avatar
    Feb 2013
    Oregon
    Also, many report that, due to the o ring on the top of the dipstick, when they push the dip stick down the seal from the o ring causes a pressure increase that forces the oil higher up the dipstick than what it is supposed to be measuring. Perhaps you are experiencing this? One way to find out is to remove the o ring and check again and compare readings...then let us know!
    Feb 2013
    Oregon
    Quote Originally Posted by wrx frog View Post
    I believe this is true...there is a significant bend in the dipstick tube as it does into the pan and this creates the "high on one side, lower on the other" oil readings...now if we only knew which side of the dipstick we are to believe...
    Registered User tesla317's Avatar
    Aug 2012
    Quote Originally Posted by garzdos View Post
    I thought I was crazy...I dipped mine over and over wondering why in the heck one side was higher than the other! And I wasnt sure which to believe lol
    The low side. Worst case scenario (or as Ricky said, "Worst case Ontario").
