No Reverse
Results 1 to 9 of 9
This is a discussion on No Reverse within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all I'm back again! 02 wrx wagon 5 speed, won't go into reverse. doesn't even feel like its trying ...
    Registered User SQ-REX's Avatar
    May 2002
    wisconsin
    No Reverse
    02 wrx wagon 5 speed, won't go into reverse. doesn't even feel like its trying to go in. I have tried 1st then going into it, rocking it and even had my friend push it a few feet while I tried it. Linkage seems ok and all other gears work fine.
    Registered User RichD514's Avatar
    Jun 2012
    Long Island, New York, United States
    Keep doing the subie-shuffle.. It'll eventually slip in. Also try shifting from 2nd to reverse
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    SQ. Any chance you need a tranny fluid change?
    A bent fork could unfortunately be the cause. Hope that's not it. Good luck getting it in! Don't force it.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    May 2002
    wisconsin
    Brand new fluid and the fork looked fine when we put it back together. The tranny did sit for almost 2 years without fluid in it, while I played daddy daycare for my little one. Its the scooty's mix if your wondering. would it cost alot to fix if I need to pull it? Does the travel of the fork matter? All of the other gears work fine.
    thanks much
    May 2002
    wisconsin
    Bump
    May 2002
    wisconsin
    What is the reverse check sleeve?
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    ^ what he said
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    How old are your bushings? Have you checked the mechanical operation from the shifter to the clutch?
    May 2002
    wisconsin
    everything in the car less then 5000 miles but it was in a frontal accident. Feels like something is locking the reverse gate out, it does not even go down into the gate to start with.
