what is the best way to remove wrx engine and trans??
Results 1 to 7 of 7
This is a discussion on what is the best way to remove wrx engine and trans?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; what is the best thinbg to do?.. im removing both engine and tranz.. is it easyer to split them and ...
    Oct 2007
    what is the best thinbg to do?.. im removing both engine and tranz.. is it easyer to split them and remove or drop box and trans together out the bottem? or together out the top? ive gota remove cross member anyway so mayb out the bottem is the best option?
    Split and out the top does work. "Easy" is relative. Depends on your roof, your hoist, and your lifts.
            MainFrame's Avatar
    Austin, TX
    Oct 2007
    yeah i can get a hold of a two post hoist so lifting car isnt a trouble im doing a complete wrx conversion on a fwd impreza so ive got to use front and rear cross members anyway so i think droping out the bottem all intact could be the best option?
    Never done that. Split - motor top - gearbox bottom I know works.
    Oct 2007
    yeah ive done motor out the top but never removed trans before. i cant see why it wont work dropping them both out the bottem just leave engine on cross member mounts and un bolt cross member from the chassis then lift car off the motor and tranz? and do the opposite when i put it in the new shell
            MainFrame's Avatar
    Austin, TX
    This is how I've done it.. but supposedly you can drop the motor out the bottom if you have to.
