Creaking near the transmission when accelerating
Results 1 to 4 of 4
This is a discussion on Creaking near the transmission when accelerating within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've started noticing a groan/creak/croak around the area of the transmission whenever I accelerate from low speed on my '13 ...
    Sep 2012
    I've started noticing a groan/creak/croak around the area of the transmission whenever I accelerate from low speed on my '13 WRX. My car already has it's fair share of squeaks, but this is not as high pitched and sounds a little more serious; like metal on metal rubbing or something bending that shouldn't be. Can anyone give me some pointers on where to look to root out the problem?
    It doesn't seem suspension related, since general bumps don't make it happen. I can reproduce pretty easily if I blip the throttle in first gear and make the car jerk forward a bit, but in general it happens most of the time that I accelerate from a stop.
    I'm no car expert, but it sounds like the motor or transmission mounts are under too much stress when I accelerate. Even if I'm not pushing it too hard.
    Car is stock, except for cobb shifter bushings (front and rear). I did hit a decent sized speed bump too fast a few weeks back (couldn't see it), but haven't had other symptoms. Nothing looks obviously damaged around there.
    Is this just the usual WRX groans and squeaks that everyone talks about or is this something fixable or worse, really broken?
    Sep 2009
    socal
    I would just take it to your dealership and have them check it out since you have a warranty.
    Registered User wrx50's Avatar
    Jun 2012
    MA
    Cobb shifter bushings. Get under there and lube them with some green waterproof grease. You will have to do it about once a year. My car does the same thing
    Sep 2012
    Quote Originally Posted by wrx50 View Post
    Thanks for the suggestion. Trip to the dealer is not convenient, so it would be great if it's something as easy as that.
