2011 Sti Power Steering Problem........Broken pump?
Results 1 to 6 of 6
This is a discussion on 2011 Sti Power Steering Problem........Broken pump? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Purchased  a 2011 sti only has 16k miles. At the time when I made my purchase, I already noticed the power steering was ...
    Jul 2009
    Purchased  a 2011 sti only has 16k miles. At the time when I made my purchase, I already noticed the power steering was hard to turn when the car was not moving. Since I got a great deal on the car, i was thnking I maybe able to fix the issue by changing the power steeringfluid. I changed the fluid but no luck. I also took the car to dealership see if they can fix it, but they denied the warranty work since I have coilover, swaybar and catback in the car. Dealership tried to tell me that the stiff steering is caused by my whiteline swaybar and kartboy endlink.................I didn't argue with them since they didn't charge me any money. My power steering pump has no leak, and I don't see any bubble in the reservior.
    Here is the problem: when my car is cold, the power steering is perfect with no issue at all, but once it warms up l, it's hard to turn when the car is not moving. If I try to turn all the way to one side, it gets harder and steering wheel shakes a little bit sometime. Do you think it's time for a new pump even my car has such low miles....? If I want to have a new pump to be installed, beside the pump,are there any more parts or any fluids I need for the installation?
    Thanks for helping
    Check front pressures and even alignment after making sure the steering joints are OK. If there is a whine check the belt. I bet the dealer wasn't all that wrong; I suspect suspension may not be helping.
    One way to wreck a pump in a few moments is doing doughnuts at full lock, but if you've not done that then see above. Pump should be new as you say. Odd.
    Jul 2009
    What i don't understand is why it's so hard to turn when the car warms up, but no issue at all from cold start......
    Hm... I wonder then if temp and pump pressure are related. I tend to suspect the pump itself last but that may be bias.
    Jul 2012
    New Hampshire
    i read somewhere that a guy was having problems turning his wheel because the top hat on his coils were a little messed up, i don't know if that would be it?? just an idea
