timing belt question
Results 1 to 4 of 4
This is a discussion on timing belt question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so, i know the timing belt should be changed at 105k based on the maintenance schedule however, is this an ...
    May 2007
    orlando flawduh
    so, i know the timing belt should be changed at 105k based on the maintenance schedule however, is this an item that should be done at a certain age regardless of mileage?
    my wrx will be 7 years old in september but i have just barely over 69k miles. most cars average about 15k a year so realistically based on that, most people would change their belt at 7 years of age anyway. get it? make sense? am i going crazy? lol
    desiree
    Yes there is a time limit on the service as well as a distance limit. I don't recall off hand but check your manual, it lists the number of months after which the belt should be replaced.
    I have found that visually inspecting the belt isn't all that helpful. Mine looked great when the time (ahem! pun!) came to replace it, and I almost felt bad doing so because the old belt looked so "good."
    EDIT: For US 2,0L cars it's actually easier to remember than I'd thought, it's 105k miles or 105 months. Behold, pg 2 of the following:
    https://home.comcast.net/~chmoore3/p...aintenance.pdf
    So that's 8 years and 9 months.
    May 2007
    orlando flawduh
    thanks! i'm going to look in my book and see if its different for a 2.5L.
    desiree
    Registered User Formula156's Avatar
    Jan 2013
    Orlando
    Ok I did a little bit of search cause I was wondering also. so apperantly the rubber on the belt goes off with age and requires to be replaced regardless of 105k or 105 months.
