2010 wrx AC problem
Results 1 to 5 of 5
This is a discussion on 2010 wrx AC problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 2010 wrx blows air but its not cold by any means. But it does blow cold air some times ...
    Registered User BEASTmode632's Avatar
    Nov 2012
    Chatlotte, NC
    2010 wrx AC problem
    My 2010 wrx blows air but its not cold by any means. But it does blow cold air some times but not very often. Has anyone else had this problem out of this new of a car? Can it just be fixed with a can of freon?
    2015 Subaru WRX : ISC Coilovers........
    Jul 2013
    Tampa, FL
    Check your a/c filter inside the glove box. I replace mine yearly, but when I first bought the car (used) it was a freaking rats nest. Might be impacting flow?
    -2010 WRX
    |AEM Intake|Cobb Stage 1|
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Could be an issue with your cabin filter as mentioned above. Could also be a charge issue like you mention (freon). I'd start with your cabin filter since that should be replaced somewhat frequently anyway, then see if there is any improvement. From the sounds of things I'm leaning towards a re-charge.
    Nothing can just be fixed with a can of freon.
    If the above doesn't solve the issue suspect a blockage or a leak. Find out what your pressures are and go from there.
    Since you're asking this implies taking it to a shop or the dealer if you are still under warranty.
    Nov 2012
    Chatlotte, NC
    I had no idea there was a cabin filter. I figured it was a leak but i did get the car used so theres no tellin. Guess ill check that first and go from there.
