chirping noise at idle, gets faster with rpms
Results 1 to 6 of 6
This is a discussion on chirping noise at idle, gets faster with rpms within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my car is straight stock minus a turboxs catback. Lately I've been noticing a chirping noise at idle that speeds ...
    Aug 2012
    Tucson, AZ
    my car is straight stock minus a turboxs catback. Lately I've been noticing a chirping noise at idle that speeds up when the rpms increase and it's been getting louder since I bought the car. If anyone is familiar with the high pressure fuel pump chirping noise in the FRS and BRZ, it sounds a lot like that...so first guess was to even see if I had the same part. For those who do not know what it sounds like, here it is. Any thoughts on what it is or even where to start? the sound sounds like it's coming from the same area where the high pressure fuel pump is located on the BRZ and FRS
    FR-S & BRZ High Pressure Fuel Pump Cricket Noise - YouTube
    Registered User hirowinn's Avatar
    Jun 2012
    stoughton, ma
    i had a problem like that recently. the problem was a bearing in one of the pulleys. swapped in a new pulley and it was gone. cheap part too if that's your problem..
    Aug 2012
    Tucson, AZ
    hopefully a nice easy baring if that. it would suck if its a cam gear bearing
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    I'm hearing this sound already in my BRZ. Trying to decide if I care. Apparently they'll put a new one in, but it will just start chirping again after a while.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Registered User MOTION's Avatar
    Oct 2011
    Mandeville, La.
    Are you all talking about the a/c compressor chirp or that deep down valve tap sound? Try turning the compressor off and see if the sound continues.
    Aug 2012
    Tucson, AZ
    you should at least get it replaced...they might actually have an updated fuel pump that doesn't die after the first week of owning it.
    no its not the compressor, I looked this morning and found it to be on the power steering pump side but its not the pump, so figured its the pulley. I removed the belt and spun the pulley and it was making a clicking sound. I don't believe that is supposed to do that and think that's the problem. my next question is what are the chances of it jst being the pulley and not internal to the pump...just so I know what needs replacing. I don't want to have to buy an entire pump and pulley if I don't have to...rather just a pulley.
