Dead zone isnt at 12 o'clock?
Results 1 to 10 of 10
This is a discussion on Dead zone isnt at 12 o'clock? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello All, I'm having some issues with my steering in my 2012 WRX premium and I'm at a loss for ...
    Registered User cctoast's Avatar
    Sep 2012
    Montpelier, VT
    Hello All,
    I'm having some issues with my steering in my 2012 WRX premium and I'm at a loss for what it is. The Issue is this: When driving down the road, the steering wheel is slightly cocked to the right, it is in line with the steering column plastic, which is slightly off. It almost feels like the entire dead-zone has been shifted to the right. When I turn the car right, it takes much more input and experiences more body roll than if I turn to the left. Turning left feels okay with a firm steering response in both the wheel and on the road.
    I recently had an alignment done and new tires mounted and balanced. I went back to the shop where the work was done, and spoke directly with the master tech who did the work. My family has been going to this garage for over 15 years, and I have full confidence in their mechanical abilities. However, they are not "performance oriented" in any way, so little things like "my steering is off 3 degrees" doesn't resound with them.
    Anyhow, the alignment is pretty good, the car does not pull and drives dead straight. The only thing is one of the tires is at -0.01 toe, and the caster is fairly far out of where it should be.... It is also important to note that I am planning on replacing my front struts in the near future, as they are feeling a bit soft. The only mod done to the car is a SPT strut bar, installed by the dealer.
    So I guess my question is, what is causing this? Is it the fact the wheel is just not centered? or Could it be soft struts? Caster?
    Any help would be greatly appreciated!
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    It has to do with the position the wheel is at when the alignment is done. My car is the same way: I didn't completely zero the wheel out during the alignment... it takes a little getting used to, but it's fine.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    mine was the exact same way. slightly off to the right, but in line with the crooked column plastic right from day 1. it annoyed the hell outta me
    so i made the dealer fix it to my liking. it took 3 trips but they finally got it right. they need to get the toe to as close to 0.00 as possible if i remember correctly. think there is a +/-0.05 leway in the toe specs for "normal" but that small amount makes all the difference. at least it did to my car.
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    One of two issues at play here:
    1. Your wheel wasn't 100% straight when the shop aligned it. To give you an idea, your 3 degrees translates into about 1/8 turn on each tie rod which is hard to meter when you are under there. Not to mention when you tighten the jam nuts on the tie rods, they can move a smidge.
    Its well within facotry specs and will do nothing other than annoy you.
    2. Your camber is set at dead even across the front instead of a slight negative pass side bias, as is common to account for road crown.
    Either way to fix:
    Essentially if you turn the wheel left so that the steering is "dead straight", your left wheel is pointed the absoulte smallest amount to the left as is your right wheel. You would adjust both tie rods evenly starting at the drivers side. You would need to tighten the Drivers side tie rod to bring it in to center, and loosen the pass side one to move it ever so slightly out.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User cmayba's Avatar
    Feb 2013
    Upstate NY
    My car is the exact same from the factory, off a touch to the right...it annoys the hell outta me! I was thinking about taking it back to the dealer too. Glad too hear I'm not the only one.
    Jul 2013
    Atlanta, GA
    I just bought my 13 and it's pulling to the right. I'll be at the Dealership on Monday to get it fixed.
    It's good to know that "NORMAL" is a WRX that drives straight!
    thanks,
    Phillip
    Sep 2012
    Montpelier, VT
    Alright guys! I appreciate all of the responses!
    I talked a little more with the guys down at the shop, and the plan from here is i'm gonna leave him a tape mark on the column and steering wheel so that when they do the alignment with my new struts, he'll just line it up how I want.
    This sounds like the most likely of the 2. I have owned this car for less than a year, and I have put 42,200 Miles on it. I'm behind the wheel enough that little things like that drive me nuts! haha
    Anyways, thanks for the help and peace of mind.
    Jun 2006
    Nor Cal
    No prob.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Jul 2013
    Atlanta, GA
    Took the car to Stivers Subaru this morning and they found that my car was out of alignment from the factory. Fix it and now it drives great!
    Quote Originally Posted by Turbo8u2 View Post
    thanks,
    Phillip
    -Phillip
    2013 WRX STI WRB
    Registered User UAC-2145's Avatar
    Jul 2013
    My 13 does the same thing. The wheel is slightly to the right. The alignment feels right on to me and I don't plan on getting it looked at. It has to with the position of the wheel at alignment like zax said. The alignment tech at the factory must have been in a hurry to get out on a Friday afternoon and was probably a little sloppy when he locked the steering wheel in place to do the alignment.
