boosting issue...(02 STI)
Results 1 to 5 of 5
This is a discussion on boosting issue...(02 STI) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok so last 4-6 weeks I have been getting a strange noise when the boost kicks in...no more nice whistle, ...
    May 2013
    Canberra, Australia
    ok so last 4-6 weeks I have been getting a strange noise when the boost kicks in...no more nice whistle, rather it sounds like a leaking exhaust (screwed airflow), and also it feels like the boost isn't at its full potential...the car doesn't really kick as much =[ however when the car is not boosting then it runs perfect...
    2 mechanics have looked over it and found NO leaks in any part of the exhaust...however 1 did highly possibly find a petrol leak.
    could this petrol leak be the cause of this? if anyone can suggest anything else it may be (turbo issue? etc) pls comment!
    when love of power... overcomes the power of STi, the world will see peace
    Fix the fuel problem. Check for vacuum and boost leaks again. Check the fuel pressure regulator.
    Palmyra, NJ
    None in the exhaust you say...so start looking pre and post turbo for leaks.
    And also fix the fuel problem.
    May 2013
    Canberra, Australia
    fuel pressure regulator?
    will this tell me (certain) if I got a petrol leak? my mechanic has only had a rough look so far so just estimating ATM.
    Im getting it checked through another good mechanic on Tuesday so I shall update then.
    Palmyra, NJ
    Quote Originally Posted by gorecki-STI View Post
    Its just a common place for a fuel leak. If your car is relatively older as well, fuel lines my also be prone to cracks, causing leaks.
