2013 sti vacuum issue
Results 1 to 8 of 8
This is a discussion on 2013 sti vacuum issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2013 sti stg 1 cobb ap aem intake and Gs aos are my mods, Ap and aem intake using ots ...
    Registered User starkall's Avatar
    Sep 2010
    2013 sti stg 1 cobb ap aem intake and Gs aos are my mods, Ap and aem intake using ots 93 map. My boost gauge will only read about -6 vacuum on idle and builds boost very easy with little throttle applied. I just noticed it started doing this recently. I can reach my target boost of 18psi. And the defi boost gauge im using reacts really slow while reading vacuum. It use to be very quick. The ap will only read about -6 to -10 on vacuum while at idle and stays around -1 to -5 vacuum while maintaining a steady speed on the highway. It use to be around -19 at idle and around -15 on the highway. Cant find a vacuum leak either.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    How are you checking for leaks?
    Resident Tuner @ WTF Tuning
    Sep 2010
    Soapy water is the best I had today
    Registered User anpato's Avatar
    Jun 2012
    If you can get to a smoke test machine use that, if not then check all vacuum lines and throttle body hose.
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
            MainFrame's Avatar
    Austin, TX
    Try performing a boost leak test starting pre-MAF.. that should uncover any leaks.
    Sep 2010
    Found a tiny pin hole in the vacuum line for my boost gauge.
    Palmyra, NJ
    That cheeky little bastard! Good find.
    Sep 2010
    The ap reads in psi for vacuum though so is about double what it reads in terms to a boost gauge for vacuum.
