03 WRX overheats at highway speeds!!
Results 1 to 13 of 13
This is a discussion on 03 WRX overheats at highway speeds!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Sorry if theres already a thread on this but I've searched and searched for an answer. I have an 03 ...
    Registered User neddy8823's Avatar
    Dec 2008
    WY
    Sorry if theres already a thread on this but I've searched and searched for an answer. I have an 03 WRX Wagon and when I get out on the highway the temperature will rise when Im in 5th gear and before it gets to the red I either rev the motor or downshift into 4th and give it some gas and it creeps back down to normal temperature. Then when i go back to 5th gear it does in again??? I've read that the 03 radiators suck. Does anyone have any suggestions before I trying buying a radiator? I took the thermostat out and put it in hot water and it opened up.
    Jun 2012
    Boca Raton, FL
    I am thinking water pump. Perhaps the blades are rotted and not moving much water at lower RPM.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Could be any number of issues.
    How many miles?
    Timing belt service with water pump been done?
    Have you kept up on your cooling system maintenance (replace coolant every 30k with factory coolant and deionized water)?
    That will help us narrow it down.
    But it could be:
    * Low coolant
    * Plugged radiator
    * Air bubble in the system
    * Malfunctioning thermostat (try a motorad failsafe one)
    * Bad water pump
    * coolant temp sensor
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Check for circulation. If not, take out rad and take it to a shop, it's cheaper than a pump. Do pump only as last resort. If you have circulation suspect leak.
    Dec 2008
    WY
    Timing belt and water pump were done at 92,000 miles and I have 125,000 now. The coolant has been changed a couple times in that time frame. I tested the thermostat in hot water and it checked out okay. I tried having the cooling system flushed at about 115,000 miles and it seemed to help for a little bit. Coolant doesnt turn a nasty color and theres none leaking into my oil which had me rule out the head gasket.
    Palmyra, NJ
    System's been properly burped?
    I'd still think Thermostat or radiator though...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by neddy8823 View Post
    03 Radiators suck only because they're known to crack. If your car is overheating and the coolant level is normal (and burped properly), it's not the radiator. As mentioned, I'd flush the coolant, and add new coolant using Subaru OEM coolant and Subaru Coolant conditioner. Before adding the new coolant, I'd check the thermostat and water pump. In all honesty, the fact that the car overheats at lower RPMs sounds like a water pump problem -- the water pump drives parasitically off of the timing belt.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Why?
    Jun 2006
    Nor Cal
    03 Radiators suck only because they're known to crack. If your car is overheating and the coolant level is normal (and burped properly), it's not the radiator..
    Actually it still very well could be the radiator. The plastic radiators in current cars are known to become blocked overtime. These blockages effectively clog the cooling tubes and decrease the surface area that can dissipate heat. If the blockage gets large enough and close to the water pump side, it will actually restrict or stop the water from circulating causing pressure build ups and super heated areas.
    Plastic radiators can also not be boiled and flushing does very little to rectify the problem.
    I'd bet he has a 30-40% blockage in his radiator causing the issue.
    My brother in laws plastic radiator became so blocked it boiled the water in 1 end tank, created steam and blew a dollar bill size chunk out of the radiator.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by 06wrx4me View Post
    Then why would the blockage cease at increased RPMs? The pressure does increase, but then I'd expect the blockage to either blow the radiator (as you have suggested) or cease altogether.
    Facebook me here
    Jun 2006
    Nor Cal
    The water pump spins faster at higher rpms. Since the water pump is positive displacement, the flow increases as rpms increase. Thus at higher rpms, the velocity of the coolant moving through the tubes of the radiator (that aren't blocked) as well as the engine increases, improving the overall cooling systems effectiveness.
    Not to mention as rpms rise, road speed increases as does the mass flow rate of air through the radiators fins, increasing convection and overall system effectiveness.
    His symptoms are exactly what I have seen with blocked radiators in the past.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Dec 2008
    WY
    Why?
    One time was to flush the cooling system and the other was to test the thermostat.
    Dec 2008
    WY
    Awesome thank you for your help. Im going to try getting an aluminum radiator and see if a new one solves the problem!
