Stuck Nut Connecting Downpipe to Turbo
Results 1 to 14 of 14
This is a discussion on Stuck Nut Connecting Downpipe to Turbo within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I had the long block replaced under warranty. When I tried to take the stock downpipe off, the nut appears ...
    Registered User wrx650's Avatar
    Feb 2012
    Cleveland, OH
    I had the long block replaced under warranty. When I tried to take the stock downpipe off, the nut appears to be completely cross threaded and now won't move in either direction. Does anyone have a suggestion for how to get this off? This is the one I am talking about:
    -Noah
    2009 Spark Silver Metallic Sedan - Stage 2+
    Stink-Eye Mob #91
    Help Me with My Build Thread : http://www.clubwrx.net/forums/builds...wrx-sedan.html
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    You might have to use a "nut cracker" to break the nut without damaging the stud. Check these out:
    Nut Splitter Tools — 2-Pc. Set | Nut Splitters| Northern Tool + Equipment
    After the nut is broken free, you'll probably have to replace the stud, but that will be much easier to do if you use the tool above and don't just grind the bolt off.
    2007 Outback 3.0R wagon
    Get a nut splitter, two spare nuts and two spare studs just in case. Also have new gaskets on hand depending on what you're doing and how old they are.
    Feb 2012
    Cleveland, OH
    Thanks guys. I will look into getting one of those nut splitter. My friend also has a stud removal kit and we will also give that a shot.
    -Noah
    Stink-Eye Mob #91
    Palmyra, NJ
    So your nuts are stuck? You might just have to bust a nut.
    Wait...we still talking about cars here?
    Nov 2009
    It doesnt look like you used any PB Blaster. Try using some PB Blaster and let it soak for a day. Then heat the nut and try again. From the picture you posted it does not look cross threaded. Use a 6 point wrench or socket.
    Palmyra, NJ
    ^^^Good idea as well...I actually have had better results with CNC Freeze-Off, but same idea. Heat is your friend as well. Simple blow torch would be enough to heat it.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Are you using a breaker bar? Only way to get factory gorilla torqued bolts loose.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Palmyra, NJ
    Quote Originally Posted by rage-wrx View Post
    I beg to differ...tiny quarter inch drive ratchet was the only thing that got my last bolt loose.
    Jan 2012
    Philly Area
    I have borne witness to the Great and Powerful Quarter Inch Ratchet. Let no one deny it's might!
    - Will
    Aug 2012
    Alexandria, VA
    I took no prisoners on my OEM downpipe removal. Use a 22" breaker bar and one pull broke them free. Getting the angle was the hardest part. And yes, I did let them soak in some PB Blaster for 5 minute prior. Overkill? Maybe, but came off without any drama.
    Oct 2010
    Portland, OR
    Quote Originally Posted by Delnari View Post
    Yeah, PB Blaster and an 18" breaker bar were good enough for me too. If you're using a breaker bar, 6 point sockets are mandatory.
    Palmyra, NJ
    Quote Originally Posted by Rambo View Post
    Completely agree here, otherwise you'll be rounding bolts and effing yourself over.
    Feb 2012
    Cleveland, OH
    Ended up getting getting it off. The stud sheared off and then I used a stud extractor and replaced it. Then, one of the other ones got stuck and I cut the nut off and replaced the bolt and nut. I will invest in a nut splitter in case this kind of thing happens again.
    -Noah
    Stink-Eye Mob #91
