Intake Manifold Removal Difficulties
Results 1 to 3 of 3
This is a discussion on Intake Manifold Removal Difficulties within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am attempting to remove my 08 wrx engine since it is blown and i need a new short block ...
    May 2013
    I am attempting to remove my 08 wrx engine since it is blown and i need a new short block and to re-machine my heads. I am stuck on removing the intake manifold, for some reason the fuel lines that run under the intake are connected to it by a metal piece with a bolt on the underside, i cant find a way to get at the bolt and i cant find a way to pull the fuel line from the metal piece either, any one have any suggestions? Im stuck and cant go on without disconnecting them somehow. its just 1 fuel line that i cant get to and i dont see a way around it besides cutting the hose
    Nov 2012
    its hard to tell without seeing the whole engine but i would leave it connected and lossen up all the intake bolts and lift it up to see if you can get at it half flipped up. older style you leave everything on and just pull the main lines and wires off. havent done an 08 yet
    May 2013
    yup i actually messed up and just cut the line, only to find out you dont need to remove those hoses as long as you remove the TGV housing thing too... oops. oh well i was gunna throw on some new hoses anyway
