2002 wrx help!!!
Results 1 to 9 of 9
This is a discussion on 2002 wrx help!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys, I'm new to this site, and am glad i found this, i have been learning alot from you ...
    May 2013
    N.E. PA.
    2002 wrx help!!!
    Hi guys, I'm new to this site, and am glad i found this, i have been learning alot from you guys. My problem is that i bought a car for my son which is almost 16. We knew when we bought this car that it had timing problems, so we got the car home we tore the front end of the motor apart it had 2 pulleys blown apart. We replaced them with ones from subaru, aligned the timing correctly, and found out it had no compression.My questions are what an i looking at? I'm no mechanic by no means, i use to be into hotrods before i had a family, so i figured me and my son can learn something new. Any info will be greatly appreciated. Thanks john
    It's an interference motor. If timing jumps there can be top end damage and/or even bottom. Maybe try a leak down to see if it's "just" valves though there's no way of which I'm aware to exclude more than valves without eyeballing it once it's apart.
    People wreck these every day; is there a used motor you could get cheap?
    Oct 2011
    Santa Ana, CA
    Timing problems now no compression? My guess would be bent valves =/
    Posted from a fone.
    May 2013
    N.E. PA.
    thanks for replying guys. how involved is it totake the heads off?
    Two choices: motor in or motor out. After that, it's what you just did for the timing plus the heads.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by jonez View Post
    Yes. A leakdown test would be considerably more comprehensive for your needs than a simple compression test. However, as SD mentioned, since the EJ motors are interference motors, cam pulley failure usually results in damaged pistons (where the valve contacts the piston) and damaged valves. Fixing either would necessitate the removal of the heads.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    May 2013
    N.E. PA.
    Thanks guys for the replies. Now i have to figure out how to get the top half apart. Any suggestions?
    Nov 2012
    pull the motor. its the safest way to remove the heads without dropping anything. the head bolts are under the cams and its just a pain to pull the cams in the car. SOHC motors can be done in the car but i always pull the motor on DOHC
            MainFrame's Avatar
    Austin, TX
    First step will be pulling the motor.. once you get it out of the car and on a stand it should be fairly clear how to go about disassembling it.
