A few questions on changing trans oil.
Results 1 to 15 of 25
This is a discussion on A few questions on changing trans oil. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So Im going to change my trans oil in the next few days in my subi and I got some ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    So Im going to change my trans oil in the next few days in my subi and I got some questions.
    1. Is there a dip-stick in a 2011 WRX STi to check for fluid levels?
    2. what's the best fluid to use?
    3. do I need anything else besides the fluid to complete the oil change?
            MainFrame's Avatar
    Austin, TX
    1. yes
    2. there are several synthetic fluids that are comparable
    3. no
    Nov 2011
    North Jersey
    So where would I locate that dip stick? and also, what oil do you suggest?
    Jan 2012
    New Jersey
    I just changed mine last week @ 30K. The dipstick should be on the passengers side under the intercooler.
    DIY: Transmission Fluid Change You will need to adjust a little since you have an STI
    I got my stuff from 42AutoSports I also changed the rear diff fluid as well (deff gett a fluid transfer pump)
    I ended up getting some clear hose from home depot and attached it to a funnel so that I would not have to worry about taking off the intercooler.
    You should need some Jackstands, T-70 Bit, Funnel or two, 1/2" socket wrench, breaker bar, Oil catch pan
    CFLip2x 2012 WRB WRX Build
            MainFrame's Avatar
    Austin, TX
    Look under the hood, there are two dipsticks, one is engine oil, the other is transmission fluid (toward the firewall, passenger side by the turbo).
    I suggest RedLine, Amsoil, Motul, or Extra-S.. there are other's as well, but those are the ones I have personal experience with.
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    Subaru Extra-S, done deal. Take your empty milk jug to your Suby dealer and ask for a fill from their bulk barrel. And beware, trans/dif fluid is real stanky and tough to clean of your concrete! I got my T-70 bit online for very cheap, arrived in 3 days.
    GLWI
    Registered User Stawgn10's Avatar
    Apr 2010
    Colorado Springs
    I don't think there is a dip stick for the sti. Owners manual section 11-21, under NOTE:
    There is no transmission oil level
    gauge for STI. Consult your SUBARU
    dealer to check the oil level.
    I could be wrong, I own a wrx.
    2010 WRB WRX wagon
    Jan 2012
    New Jersey
            MainFrame's Avatar
    Austin, TX
    Wow.. that's kind of retarded. I guess whatever works.
    Nov 2011
    North Jersey
    Meanwhile you guys got me staring at my engine bay like I'm lost... hahaha okay so I need one of those special "pump" things to get it up in there rite? lol
            MainFrame's Avatar
    Austin, TX
    I would just pour it in a funnel.
    Nov 2011
    North Jersey
    it fills via the engine bay?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Mike193 View Post
    yes.. same place the dipstick used to be.
    May 2010
    Pittsburgh, PA
    Hope I am not too late.
    You no longer fill it from that hole. You now fill it from the side. There is both a fill and drain plug. Just fill it up with whatever means possible (I would recommend a funnel and tubing) until it over flows the fill hole.
    The left the bolt on there where the dip stick used to be. Who knows why.
    2011 STi Build Log
            MainFrame's Avatar
    Austin, TX
    Ahh.. that makes more sense. People were saying fill it till it overflows, but for that top filler it would be over filled.
